used B series manifold and 2.5 downpipe cat remove
Old Mar 15, 2004 | 03:25 PM
project dc2's Avatar
Default used B series manifold and 2.5 downpipe cat remove
log manifold. and 35MM wastegate and elbow. to be used with mercades 5 bolt turbine flange ( down2turbo, etcc ) most of the rebult turbos on ebay use this flange. hard to find.
was on a 94 GSR.
Old Mar 15, 2004 | 05:45 PM
Infinity_Racer's Avatar
Default Re: used B series manifold and 2.5 downpipe cat remove (project dc2)
price? willing to seperate?
Old Mar 15, 2004 | 06:23 PM
Default Re: used B series manifold and 2.5 downpipe cat remove (Infinity_Racer)
280$ for both items. what did you want from the kit ?
Old Mar 15, 2004 | 08:08 PM
Sohc Driver's Avatar
PM sent..interested in both
Old Mar 16, 2004 | 08:14 AM
Default Re: used B series manifold and 2.5 downpipe cat remove (Sohc Driver)
ttt
Old Mar 16, 2004 | 10:57 AM
downpipe sold ! manifold 200$
Old Mar 17, 2004 | 02:17 PM
ttt
Old Mar 19, 2004 | 08:08 AM
ttt
Old Mar 19, 2004 | 08:36 AM
Carlito Brigante's Avatar
is this manifold good for a sc61 placement? if os ill take it.
Old Mar 19, 2004 | 10:42 AM
Default Re: used B series manifold and 2.5 downpipe cat remove (hiddenEM1)
nah this one tucks in MAJOR close, you gtota really grind out the webbing, it works good if you really want some tight clearance away from your fan n all that. i can make you a log to work wit hteh SC61, 275 shipped.
Old Mar 22, 2004 | 09:27 AM
ttt
Old Mar 24, 2004 | 12:20 PM
ttt
Old Mar 25, 2004 | 02:21 PM
tttt
Old Mar 26, 2004 | 09:44 AM
ttt
Old Mar 27, 2004 | 01:21 PM
ttt
Old Mar 28, 2004 | 05:49 PM
AirWaveGT's Avatar
manifold work w/ ac? and will a garrett 50 trim t3/t04e fit well w/ it?
Old Mar 30, 2004 | 07:28 PM
iNetForce's Avatar
Default Re: used B series manifold and 2.5 downpipe cat remove (AirWaveGT)
is it a/c friendly?
Old Mar 31, 2004 | 12:08 PM
hyperB16Turbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">nah this one tucks in MAJOR close, you gtota really grind out the webbing, it works good if you really want some tight clearance away from your fan n all that. i can make you a log to work wit hteh SC61, 275 shipped. </TD></TR></TABLE>
I need one for a SC61 with tail wastegate flange.
pm me when your done, so I can pay you.
Old Apr 1, 2004 | 09:14 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AirWaveGT &raquo;</TD></TR><TR><TD CLASS="quote">manifold work w/ ac? and will a garrett 50 trim t3/t04e fit well w/ it?</TD></TR></TABLE>
yeah a garrett will fit fine with it, it just takes a lil grinding, it fits really close tot eh block i had a garrett .57 trim turbo on .
sorry for the delay ive been on vacation for a few days.
Old Apr 2, 2004 | 03:27 AM
ttt
Old Apr 2, 2004 | 02:22 PM
how much you trying to get now for it?
shipped
Old Apr 2, 2004 | 07:36 PM
200
Old Apr 6, 2004 | 11:29 AM
ttt
Old Apr 9, 2004 | 02:13 AM
ttt
Old Apr 9, 2004 | 08:09 AM
AspectIndustries's Avatar
with a t3to4e 57 trim turbo on it, what gap clearance would it be from the AC? Thanks. Semi interested.
Also, what did you have to grind off the bottom block? A little or alot..? Thanks.
