FITV 2000 SI
Old Mar 15, 2004 | 02:10 PM
ShowSi2's Avatar
Default FITV 2000 SI
Just wondering if my 2000 civic si has FITV. I can't find the damn thing anywhere, and it has to be my idle problem b/c everything else has been triple checked and replaced. Any Help???
Old Mar 15, 2004 | 02:30 PM
stevel's Avatar
Default Re: FITV 2000 SI (ShowSi2)
2000 Si's don't have FITV's.
Look for vacuum leaks first.
make sure the idle screw on the TB is screwed all the way in. This can be a vacuum leak.
make sure you bleed the coolant. Take the radiator cap off when the car is cold, start the car up and let it run for 30 minutes. Coolant will overflow so be ready with something to suck it up. If it's not a vacuum problem this could very well be the culprit. I had the same problem on my Si motor.
s
Old Mar 15, 2004 | 08:51 PM
ShowSi2's Avatar
thank you very much, coolant fixed it...finally
wallendiaz
Apr 8, 2013 11:58 AM
J.Kempster
May 15, 2008 08:12 AM
ShowSi2
Mar 16, 2004 05:46 AM
team2n1hatch
10
Apr 2, 2003 03:32 PM
