One headlight dosen't work...
Old Mar 15, 2004 | 01:49 PM
FOrSfEd's Avatar
Default One headlight dosen't work...
For some reason my driver side headlight does not work. Low beam or high beam. I changed out the bulbs and that did not work, looked for any blown fuses didn't find any. the bumper light still works though. Anyone know what it might could be.
Old Mar 15, 2004 | 04:47 PM
Bbasso's Avatar
Default Re: One headlight dosen't work... (FOrSfEd)
Get the test light out and see if there is power going to the sockets.
first things first.
Old Mar 15, 2004 | 05:08 PM
Bradstard's Avatar
Check the ground for that light also. Use a multi-meter and see if you are getting power. I had this happen on one of my RX-7's once and it was a bad ground. Good luck. Brad
Old Mar 15, 2004 | 08:26 PM
adddddaaammmm's Avatar
check the harnesses
RageRage
Nov 3, 2013 05:08 AM
MACH 7
Jan 17, 2012 08:35 AM
powerwagon340
Honda Civic (2001 - 2005)
Dec 24, 2008 01:07 PM
StreetRiot_DRE
Lighting
Mar 6, 2008 11:49 AM
getnasty
May 31, 2005 03:04 PM
