need check engine light codes for obd1.
Old Mar 15, 2004 | 12:03 PM
gsrcivic619's Avatar
Default need check engine light codes for obd1.
if u guys have a good link with all the ecu codes for a b series obd1 ecu it would be highly appreciated. or if u know them off the top of your head im flashing 11,12,13,16,18,54,61 thanx
Old Mar 15, 2004 | 12:47 PM
Luserkid's Avatar
Default Re: need check engine light codes for obd1. (gsrcivic619)
https://honda-tech.com/zerothread?id=682412
Looks like your throwing:
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
16 Fuel injectors
54 CKF - crank fluctuation sensor
61 Primary oxygen sensor
I didnt see no 11 or 18 though.
Old Mar 15, 2004 | 02:57 PM
Default Re: need check engine light codes for obd1. (Luserkid)
thanx a lot
Old Mar 15, 2004 | 03:52 PM
H22A EG6's Avatar
damn what did you do
Old Mar 15, 2004 | 04:07 PM
Default Re: need check engine light codes for obd1. (H22A EG6)
im not sure maybe my ecu is bad what do u guys think?
Derrick_12341
10
May 21, 2018 07:41 PM
MDPL8706
Jul 12, 2006 06:31 PM
B18C_EJ8
Mar 6, 2006 10:41 AM
cheeks97R
Apr 17, 2005 09:22 AM
