Inexpensive brake upgrade for 92-95 Accords
Old Oct 19, 2001 | 08:15 AM
fastbrakes's Avatar
Default Inexpensive brake upgrade for 92-95 Accords
I have figured out that the 11" brakes from the Accord wagon will bolt on the Accord 4 cyl knuckles. This will give you an 11" brake vs the 10.3" . While not a huge increase in size, it will make a noticeable difference in stopping power.
All you need are the rotors and calipers from the Accord wagon, just swap those parts and you're done.
Old Oct 19, 2001 | 08:28 AM
Honda318dx's Avatar
Default Re: Inexpensive brake upgrade for 92-95 Accords (fastbrakes)
Nice, does that change the rotor design as well, as being a rotor on hub, instead of the shitty hub on rotor..?
Old Oct 19, 2001 | 08:33 AM
jdmbike's Avatar
New User
cool, finally confirmed info!
Old Oct 19, 2001 | 08:41 AM
urbanlegend21's Avatar
New User
Default Re: Inexpensive brake upgrade for 92-95 Accords (jdmbike)
yeah, does this change how th whole hub assembly needs to be removed for rotor replacement to a style like the Prelude or integra?
Old Oct 19, 2001 | 09:29 AM
4doorH22's Avatar
Default Re: Inexpensive brake upgrade for 92-95 Accords (MiGs)
Keep in mind. You have increased brake rotor surface. However, it wont be effective unless you change to the Accord Wagon Rotors. The pad remains the SAME size. Same surface friction.
I think you mean Accord wagon calipers.
Old Oct 19, 2001 | 10:16 AM
jdmbike's Avatar
New User
Do the dust gaurds still work or do they have to go?
Are you going to sell a kit?
Thanks
Old Oct 19, 2001 | 10:48 AM
SOHCArchangel's Avatar
well do tell more!
Old Oct 19, 2001 | 11:05 AM
4doorRS5spd's Avatar
New User
Default Re: Inexpensive brake upgrade for 92-95 Accords (SOHCkordVTEC)
Sweet. Hey, does anyone know if EBC brake pads are any good for the Accords. I'm going to sawp out my pads and shoes tomarrow, and I was wondering if they were worth getting? Thanks.
Old Oct 19, 2001 | 11:07 AM
4doorH22's Avatar
Default Re: Inexpensive brake upgrade for 92-95 Accords (accord55)
I've heard a lot of bad things about EBC and no good things.
What do you use your car for? Does it see any autocross or track time?
Old Oct 19, 2001 | 11:08 AM
New User
nope......never heard a good thing about them- may as well buy el-cheapos if you are not hard on brakes
Old Oct 19, 2001 | 11:56 AM
ArchAngel Sabastian's Avatar
New User
Default Re: Inexpensive brake upgrade for 92-95 Accords (urbanlegend21)
did someone confirm yet that the accord wagon rotor's & calipers fit?
does this get rid of the Pressed on hub problem?
how can they fit 92-95 accord thats two different gen's
Old Oct 19, 2001 | 12:03 PM
John's Avatar
New User
Default Re: Inexpensive brake upgrade for 92-95 Accords (Sabastian)
I too finally confirmed info... here is the result of my inquiry:
"we used the calipers and rotors off of the 96-97 Accord V6. you don't need
any additional parts and the difference in breaking is dependent on the how
good the driver is. we have not experienced any warpping as of yet."
if I remember correctly, the Accord V6 used the same brakes as the Accord wagon...
Old Oct 19, 2001 | 12:21 PM
4doorH22's Avatar
I was wondering myself. Well looky here, looks like they both have the same part numbers for hubs, rotors, wheel bearings, etc...
Old Oct 19, 2001 | 12:34 PM
John's Avatar
New User
Default Re: Inexpensive brake upgrade for 92-95 Accords (4doorH22)
It should fit on 96 and 97s too...
Old Oct 19, 2001 | 12:58 PM
John's Avatar
New User
Default Re: Inexpensive brake upgrade for 92-95 Accords (DunReit)
it seems that the rotor and caliper assembly may be the same from the Odessey as well...
Old Oct 19, 2001 | 12:59 PM
4doorH22's Avatar
Oh for sure. All previous Odesseys were Accord platforms.
Old Oct 19, 2001 | 01:04 PM
John's Avatar
New User
how many parts from my caliper assembly are compatible with that of a caliper assembly designed to hold a .7" larger brake rotor? i'm just trying to economize everything here...
Old Oct 19, 2001 | 06:25 PM
New User
from what model accord v6 or wagon did the pressed on hub to rotor design change?
Old Oct 20, 2001 | 03:23 PM
4doorH22's Avatar
I 6G started with rotor over hub design. I don't know if the 5G wagons had that or the hub over rotor like the sedans/coupes.
Old Oct 20, 2001 | 08:30 PM
John's Avatar
New User
According to Majestic auto parts (www.hondaautomotiveparts.com), the 5G Accord Wagon brakes are indeed hub-over-rotor design... however, the part # is the same for the rotors in the 5G Wagon and 5G EX.... same with the V6s... so, is the diagram and part numbering incorrect on the website or what? is there a better online source that we should be looking at?
Old Oct 20, 2001 | 09:09 PM
John's Avatar
New User
I just went to http://www.oem-car-parts.com and it yielded the results that i was hoping for... 5G Accord front brake rotors are different from 5G V-6 Accords and Acura 97-98 3.0CL front brake rotors... $73.15 for each front rotor...
Old Oct 20, 2001 | 10:37 PM
4doorH22's Avatar
So....? Does that mean this brake upgrade is a rotor over hub design? Sounds like we'd need to swap everything, hub, wheel bearing, rotor and caliper. Probaby not too pricey and worth it from a junkyard? I dunno I bet those calipers are rare and expensive.
Old Oct 20, 2001 | 11:19 PM
Nick M's Avatar
Arent the accord wagon brakes the same as the ITR? I heard that once. I have no idea if its true or not. Can anyone confirm this?
Old Oct 21, 2001 | 08:50 AM
John's Avatar
New User
No, the V-6 and Accord Wagons use the same hub-over-rotor design that 4G and 5G Accords use...
As for the caliper assemblies, the best source would be to look at some junk yards probably... any other source is going to be outrageously priced....
[Modified by DunReit, 5:54 PM 10/21/2001]
Old Oct 21, 2001 | 08:52 AM
John's Avatar
New User
Default Re: Inexpensive brake upgrade for 92-95 Accords (Hondasport94)
And no, the V-6 Accord and ITR brakes are not the same... I don't remember the stats of the ITR brake rotors' diameter (which may be the same size), however, ITRs had a 5 bolt design, not a four bolt design... plus the hub design on Integras is quite different than the design on Accords..
