gsr in crx no spark
i have a 94 gsr in a 91 crx hf i cant get no spark. i have a si wiring harness with a pr3 ecu and a b16a distributor brand new. sometimes it throws a code 15 (ignition output signal) and sometimes it doesn't. I had spark one time and that was it i thank it has someting to do with the wiring. I need help PLEASE!!!!!!!!!!!
everything is grounded
make sure to check your grounds. make sure you got valve cover grounded and tranny. i had no spark or fuel and the reason for this was the wiring harness wasn't grounded to the thermo housing so make sure to check that.
