grinding noise after lowering
Old Mar 15, 2004 | 06:06 AM
Behan's Avatar
Default grinding noise after lowering
i installed rsr down springs and kyb agx's on sat and i have a squeaking noise coming from the drivers side rear tire. it is a constant squeal in reverse and squeaks if i hit a bump when moving froward. the noise sounds like grinding metal or something to that effect. i haven't taken the wheel off yet too inspect it, but i wanted to get some ideas as to what may be causing it.
Old Mar 15, 2004 | 10:26 AM
Turbo_LudeSH's Avatar
Default Re: grinding noise after lowering (Behan)
Sounds to me like an uper control arm bushing. You can pick up urathane aftermarket bushing and thye are a big help with suspension. Make it feel alot nicer.
Good luck
Old Mar 15, 2004 | 10:45 AM
NoLipRacen's Avatar
Default Re: grinding noise after lowering (Turbo_LudeSH)
i would also try the brake dust shield, you might have bent it during the install and it might be grinding against the rotor...
slateEKsi
15
Aug 10, 2021 04:43 PM
Arturoej8
Suspension & Brakes
Jan 19, 2017 06:07 PM
k20eklipse
Aug 3, 2010 08:40 PM
TaffetaSI06
Honda Civic (2006 - 2015)
Aug 7, 2006 09:43 PM
JDM00SI
Suspension & Brakes
Mar 7, 2005 08:40 PM
