help please.. B16SIR1 in 91 HB DX. turns on and just stumbles when i hit gas.
Old Mar 15, 2004 | 04:56 AM
civicracer1993's Avatar
Default help please.. B16SIR1 in 91 HB DX. turns on and just stumbles when i hit gas.
im doing a swap for a friend .. he has a 91 HB DX , i went to hybrid garage and got the list for the DPFI to MPFI conversion. hooked it up exactyl how it said and we turn the motor on fine but when i hit the gas the motor wont hardly do anything but sputter and backfire and all kinds of junk,..wont rev past like 2K either.. the car is stuck in my driveway and he has to go to work in about 5 hrs.. so any help would be appreciated..
Old Mar 15, 2004 | 04:58 AM
ijjz's Avatar
Default Re: help please.. B16SIR1 in 91 HB DX. turns on and just stumbles when i hit gas. (civicracer1993)
Did you reverse that one connection? I believe its the TPS sensor.
T S R Performance's Avatar
Have you tried the fuel filter? And are there any codes on the computer about an injector misfire?
Old Mar 15, 2004 | 05:00 AM
primeredbeast's Avatar
My b16 crx dx did this and it was my ignition module in the distributor does it misfire and stuff when u give it gas?? hope this helps
Old Mar 15, 2004 | 05:01 AM
crx_88_si's Avatar
Default Re: help please.. B16SIR1 in 91 HB DX. turns on and just stumbles when i hit gas. (ijjz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ijjz &raquo;</TD></TR><TR><TD CLASS="quote">Did you reverse that one connection? I believe its the TPS sensor.</TD></TR></TABLE>
this is my bet as well..
Old Mar 15, 2004 | 05:24 AM
paybac4223's Avatar
Default Re: help please.. B16SIR1 in 91 HB DX. turns on and just stumbles when i hit gas. (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">
this is my bet as well.. </TD></TR></TABLE>
i second that!
Old Mar 15, 2004 | 05:45 AM
dynastyracingcivic's Avatar
what all do you need to do that swap
Old Mar 15, 2004 | 06:16 AM
yes i reversed the TPS connection.. its still doin it.. no codes about injectors.. code was 21 vtec solenoid cause i dont have it hooked up yet..
bonestock91
Nov 18, 2005 08:15 AM
Spork Sports
Sep 6, 2005 08:07 AM
J_J
26
Jan 8, 2005 06:04 AM
senbei
Dec 5, 2003 07:33 AM
