at idle revs jump and drop
Old Mar 14, 2004 | 07:50 PM
Variable J's Avatar
Default at idle revs jump and drop
I have a 97 prelude base model. When the car is cold the revs jump and fall about five hundred rpms. When the car is at operating temp it idles fine. I was told it could be my cold start injectors. How can I test for this. I tried to see if it would throw a code but came up with nothing. Any ideas?
Old Mar 14, 2004 | 09:13 PM
fkncivic's Avatar
Default Re: at idle revs jump and drop (Variable J)
is there a check engine light... if so could be iac or tps other than that i dunno man
Old Mar 15, 2004 | 06:15 AM
doublejz's Avatar
Default Re: at idle revs jump and drop (fkncivic)
pull the tps when its jumping up and down, and see if it stops. If it does then its your tps, if not that its either a vaccum leak, or iac
Old Mar 15, 2004 | 11:44 AM
tgreaves's Avatar
Default Re: at idle revs jump and drop (doublejz)
My prelude did the same thing and it was the eacv..
Old Mar 16, 2004 | 06:03 PM
PnX-R's Avatar
Does the 97 Prelude even have a Cold Start Injector?
Old Mar 16, 2004 | 06:32 PM
Smith Wise's Avatar
Default Re: at idle revs jump and drop (tgreaves)
EVAC purge, check the hoses...
you might get away with replacing them with much STIFFER hoses
simon.vada
Sep 23, 2018 04:50 PM
89civicstd
Nov 13, 2013 03:56 PM
lgj069
May 29, 2006 11:22 AM
dan4h22a
Oct 27, 2004 10:41 AM
