Idle jumps up and down.
Old Mar 14, 2004 | 07:22 PM
Variable J's Avatar
Default Idle jumps up and down.
My idle on startup will rise and fall over and over. When the car is warm it idles fine. I was told by my friend that works at audi it could be a problem with the cold start injectors. Anyone know how to test for this? Tried to see if the car would throw a code but nothing came up. Anyone have any ideas?
Old Mar 14, 2004 | 08:26 PM
PretecSH's Avatar
clean your IAC vavle. carb cleaner/let it dry/ put it back on. if you wanna be real safe, get a cup of water and a cue (sp?) tip and try to get as much carbon off as you can. this should fix your problem. only about 10 mins. too.
-pretec
BD-Unit
Mar 18, 2008 04:31 PM
Topdawgg
Jun 28, 2006 01:03 AM
Bgladfelter
Oct 26, 2005 05:48 AM
EsCo_EsCo
Aug 21, 2005 09:21 PM
