trouble installing speakers
Old Mar 14, 2004 | 07:18 PM
xcom's Avatar
Default trouble installing speakers
ok, i have a '99 accord sedan, with power nothing. Im having major trouble removing the door panel. im basically on the last step, i cant remove the window crank. I tried pulling it off but that really went no where. I looked in the gap pulling the door panel, and i see that the crank goes right into the outer part of the door. How do i remove this? do i pull the outside of the crank or do i pull the entire thing?
Old Mar 15, 2004 | 12:57 AM
philadd's Avatar
Default Re: trouble installing speakers (xcom)
you'll need a small wire hook... or you can pick up the tool at autozone that's specifically made for this. there's a wire clip that needs to be pulled out from between the crank handle and the door. once you remove this clip, you'll be able to pull the handle off...
Old Mar 15, 2004 | 10:02 AM
xcom's Avatar
Default Re: trouble installing speakers (philadd)
ok thanks, can you describe what it looks like? I think i know what your talking about though. The slot on the handle right?
Old Mar 15, 2004 | 10:29 AM
beantowncoupe's Avatar
yes, it is just a plastic handle with a slot in the middle to pull the clip out. The guy at the AutoZone counter will be able to help you out.
Old Mar 15, 2004 | 01:19 PM
xcom's Avatar
Default Re: trouble installing speakers (beantowncoupe)
ok i got it, thanks
pompom
Feb 28, 2006 04:41 PM
flatblk
Jul 12, 2004 10:30 AM
JDMTYPER
Jan 19, 2004 03:39 PM
StreetGT
Audio / Security / Video
Nov 5, 2003 08:49 PM
djpnj1
Sep 28, 2001 12:40 AM
