im doing a d16 swap in my d15 std hatch i have a couple questions
hey guys, my first question is
im getting a 88 si d16a6 motor, and it doesnt come with clutch flywheel can i use the clutch/flywheel off my 90std hatch? if not i can buy the tranny clutch and flywheel off him but theres some bearing noise he said he replaced the main shaft bearing and it still does it so what else could it be? he said it does it during 1rst and sometimes 2nd, he didnt tell me if the noise disppaered with the clutch pressed IN or not.
what companys make some good mild pistons for all motor applications for the d16a6? im going to run the exospeed race a6 cam, also how hard is the mpfi swap i looked at the directions looks like cake can anyone tell me how it is?
clutch and flywheel from your 90 will work fine, unless you try to use the 88 transmission - the 88 transmission won't fit the clutch due to the different spline count
justin-95si
Dec 10, 2012 12:08 AM
matt's hatch
Jan 30, 2010 06:03 PM
uNF$@#!
May 27, 2003 03:33 PM
