Need help: Installing JDM door visor
Old Mar 14, 2004 | 03:05 PM
rudeS2k's Avatar
Default jdm ITR door visor install..need help
i just recently purchased a used set of JDM door visors from ebay..it came with small screws and clips..has anyone installed one on their doors?..need help..will i need two sided 3m tape?, any pictures will help..thanks
Old Mar 14, 2004 | 03:12 PM
JDM TypeR 307's Avatar
Default Re: jdm ITR door visor install..need help (rudeITR)
Let me tell u something...
Its pretty tough to put those on.... Its frustrating...
Old Mar 14, 2004 | 03:31 PM
machgo5go's Avatar
I just installed it using the 4 clips which will go under the window weather strip which
u have to pull down like pictured on page 3 of instruction. I only screwed down clip
on the 90 degreee corner window frame on since there is a predrill hole on our R.
I eliminated the other corner 90 degree window frame clip because you have to slit into
the molding and used just a small thin piece of 3M double sided tape instead. Also I did not cut any weather strip for the clips since i pretested before install of visor and window do rolled up and sealed properly.
Good Luck!
Mr.Fairlady's Avatar
No 3M tape @ all.
THE FIRST Side is the hardest(2nd will be like 5 mins)
It is very tricky...main thing is line the visors up how they are supposed to look on the door...and make a dot w/ the Marker where the clips will be coming out to attach to the visor.
Peel the top part of the rubber seal around the window (that you will have to shave down for the clips to pop out) down a little and the clips sit in the Channel between the Seal and the metal(of the door) and the little tiny Silver Clip is what "Clips" the Black clip to the door.
You will have to make 1 hole @ towards the bottom of the door(toward the mirror) abd countersink it so the screw will go through the metal to thread to the bottom Visor Clip.
The Highest party of the door the Hole will already be there for you.and then you measure 3mm down or what ever the Instructions say and thats wheree that litte paper hook thing comes into play.
Thats kinda a cut and dry version...but you have to really understand the pic's and the weirdest part is how that Silver clip actually pops the Blk Clip to the doort to hold it secure..then teh seal kinda overlaps that.
Sorry,...but thats kinda the bst I can do right now
<----COLLIN...who is on drugs for having his wisdom teeth pulled and got the "puff daddy" cheeks.
Old Mar 14, 2004 | 03:38 PM
rudeS2k's Avatar
Default Re: jdm ITR door visor install..need help (Mr.Fairlady)
thanks guys for all the info..i'll do my best
Old Mar 14, 2004 | 09:34 PM
Bbasso's Avatar
Let us know how you do and pics of the install, maybe make a photo install help for the next person?
good luck.
crxaddikt
Jun 7, 2011 05:05 PM
ek4life
Mar 17, 2006 07:56 AM
odishaw
Jan 31, 2006 10:33 PM
shyboi4u
Oct 29, 2005 09:03 PM
bigBOI_92DA9
Jun 14, 2004 06:43 AM
