b18c almost done coupe more questions
Well I order new bearings for the bottom end and a upper and lower gasket set for the motor yesterday and that should be in on wednesday. So all that is left is to get the head done. Plus the bottom end is getting sent out and cleaned monday. I've been aiming for 13s or lower...I wont be disappointed if i run a 13.9 but I want to hit 13s consecutively. Here is my setup and Im wondering if these cams are going to help me alot or if they are even worth getting.
b18c1 stock bottom end rebuilt balanced and blueprinted
jdm 4-1 header
2.5 cat and exhaust from kteller
3 inch short ram intake
gsr throttle body bored to 64 mm with skunk2 intake manifold portmatched
now I'm debating on getting some CTR or 00-01 ITR CAMS for my setup with crower valve springs and retainers (i got the hook up on crower parts) but I still dont want to go crazy on cams incase I want to go forced induction in the next year or 2. Ive been 13s before and I feel that I need to get confident with a fwd 13 second car before I go way faster. Do you think that the CTR cams would help me run consecutive passes or should I be good with the gsr cams +2 degrees.
This is for a 1989 crx hf. I'm thinking CTR cams would definately be worth it and I'm just having trouble finding a set for around $350. Do you think that this is overkill for 13s?
DEF
jdm 4-1 header
DEF
boostedekhb
25
Oct 12, 2012 12:43 PM
StreetLethaleg6
Nov 11, 2010 11:10 AM
EK9 BEEZLER
Mar 24, 2005 08:05 PM
deftones0817
Jul 15, 2004 05:48 PM
