Motor mounts for a H22 in a 95 accord
Old Mar 14, 2004 | 01:36 PM
yellowsi99's Avatar
Default Motor mounts for a H22 in a 95 accord
I am doing a H22a swap in a 1995 Accord and I have a few questions i need some help with.
What drivers side mount should i use the Accord or the Prelude?
What shift linkage should i use?
I would greatly appreciate any help you can give.
Old Mar 14, 2004 | 01:39 PM
v4lu3s's Avatar
RTFM
you can use either linkage.
and you use the preldeu driver side mount, and shave it down slightly to fit.
Old Mar 14, 2004 | 02:19 PM
yellowsi99's Avatar
Default Re: (v4lu3s)
thanks for the info, what about power steering brackets and pumps
Old Mar 14, 2004 | 07:21 PM
matix's Avatar
Both work on power steering.
Old Mar 14, 2004 | 07:33 PM
Nick H's Avatar
New User
Default Re: (matix)
you have to use the prelude bracket and pump and get the prelude line brazed onto the end of the accord line...or just do as i did and say **** it to power steering...it's not that big of a deal
Old Mar 14, 2004 | 08:33 PM
New Image's Avatar
Default Re: Motor mounts for a H22 in a 95 accord (yellowsi99)
The Accord/Prelude motor mounts are very similar. Only the prelude ones are stiffer. You must use the accord front mount because the prelude mount is not the correct height. Use prelude mounts for the right and rear mounts. You must also match these with prelude mount brackets. As far as the drivers (left) side mount goes there are two options. Option one is to tweak either the accord or prelude mount enough to fit between the motor and mount location. Option two is to buy Hasports mount kit. This will directly bolt in without and modification. You should look into getting new mounts or polyurethane inserts if your current mounts look warn. I recommend the use of the prelude shift linkage but either should work fine. The prelude uses a different fitting to connect the power steering line to the pump. A good idea is to connect the prelude line to the accord part using a sleeve.
Old Mar 14, 2004 | 09:10 PM
Andy4dtw's Avatar
I don't mean to thread jack but I was wondering would h23 motor mounts fit my h22 swap into my 6th gen accord?
Old Mar 15, 2004 | 01:14 AM
AsiAnVenOm's Avatar
Default Re: (Andy4dtw)
man i just found out that there's more than one of you guys using the "jackass" logo...all these time i was like "daymn this guy is everywhere...in every thead..and **** how many cars does he have" hahaha..turns out that bunch of you using the same logo or signiture logo...(jackass)
jakeiscool
Aug 10, 2021 09:11 AM
Drag-Accord
Jan 17, 2005 02:59 PM
jbonehead85
Sep 28, 2004 06:24 PM
jbonehead85
Jul 18, 2004 09:17 PM
H23preludeSi
Apr 20, 2004 08:17 AM
