guage clusters? will 98 integra gsr fit in 93 civic ex?
Depends on how much work you want to do. I'm not 100% sure about the SI cluster, but I know for a fact you'll have to rewire the Teg cluster. Either way, neither are going to fill the hole perfectly and are going to require some work.
take the faces off the si cluster and insert them into your stock cluster. ive seen it odne it looks sick. if you want to do gsr itll work, but i recomment you do integra dash as well for flush fit
gsr= a lot of cutting, and wiring.
si cluster=remove needle's and face's.
Si looks cool. but you do loose some of your lights. (CEL/Seatbelt/trunketc...)
i am trying to get the whole SI cluster's "guts" into the 92-95 cluster "body"........
z-28john
Oct 23, 2014 01:57 AM
