tranny problem, need help
i think there's something wrong with my transmission. i can not shift into gear when the engine is running. only when the engine is not running. what could it be?? i'm at a loss.
WHAT YEAR PRELUDE, IT MIGHT BE YOUR MASTER CYLINDER FOR YOUR HYDROLIC CLUTCH., DID YOU PUT A SHORT SHIFTER KIT IN THERE, IF YOU DID IT MIGHT BE INSTALLED WRONG AND NOT READING THE GEARS
it's a 97 base with 80k miles.. stock clutch, no short shifter, no mods done to the tranny. it's weird too.. when the engine is running, i can't put it in gear, but when i hold it in the position of the gear ( even with the clutch pedal down) the car will move, as if it's in the clutch's friction zone.
Slave or master cylinder... Check for leaks, no leaks, then bleed of fluid and air, if then no success, then it's your clutch!
And take it off the damn caps button before I edit your post ELUD THIS. That's annoying.
i decide to just change my clutch. it's about time anyways. i ordered an ACT xtreme pp and 6 puck disk. i know this is over kill but who knows, i might go fi in the near future.
if your going to change out your clutch you can put in a act stage 3 with no modifications to your engine besides the basic intake etc etc.
here's my mods.. front/rear stb, koni yellows+skunk2 coilovers, cai, dc cc headers, 5zigen fireball exhuast, msd digital 6plus, blaster 2 coil, magnecor wires, iridium plugs, 75 shot zex
You had no need to replace the clutch....I'm positive it was just a hydraulic problem somewhere and you will still have this problem after the new install.
You will hate that clutch for what you do.
Is it just me, or is this thread about two years old? I noticed because safe driver stated about he ordered a ACT 6puck clutch and said he might go F/I in the future but in his sig, he seems to be supercharged. Also the date on the first handful of threads shows up to be from 2001.
I would like to know if the clutch was the problem.
I had the SAME problem. Long story short....I changed my clutch master and slave cylinder. That did not fix it. I think my clutch was the issue. I had it changed....but I also told the mechanic that I had a spare tranny just in case the tranny was bad.
He called me up and told me that my tranny was bad. After he changed my tranny...he never gave me back my old tranny. He told me that he had already sent it out to the dismantlers. I think he kept it. I need some proof so that when I take him to court.....I have some prrof that the clutch was the issue.
no......no.....I didnt replace anything yet
Im just wondering how long it takes to replace a clutch. Im gonna bleed it tommorow see what happens, just gotta figure out the best way to do it first.
And yes this post is 2 yrs old.............>>>>I searched
