Those with EK foglamps...
Guest
Posts: n/a
Hello.
I have a dilema about my OEM foglamps, they're 99-00 if that helps.
I took my bumper off and I had to unhook the foglamp harness. When I put my bumper back on I forgot to hook the harness back up to the foglamps. I told my friend after we had finished our project, and had the bumper on to see if all the lights, ect... worked... all but the foglights. Of course we forgot the harness!
The harness was then plugged in and when I went over to press the button it was already on the "ON" position my friend didn't click it "OFF". O well I said I reclicked it and the fogs still didn't come on.
Ok is there a foglamp fuse, if so please tell me where it is I have been lookin everywhere for it, my HONDA manual doesn't say.
I also switched out the 'OPTION' fuse (whatever that is) under the hood, still no luck.
I think the bulbs got fried.
But since they're kind of a pain to change help me rule everything else out.
Thanks!
Thanks!
if you can get to the harness then check to see if it's getting power when the switch is on (multimeter or even just a bulb with some wires hooked up to it)
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwistedSI »</TD></TR><TR><TD CLASS="quote">The fuse should be in the fuse box. Is the light on the switch coming on? And the bulbs are easy to replace. The lamps come out without having to pull the bumper.</TD></TR></TABLE>
Which fuse is it, and you're talkin about the one under the hood right?
Anyways the light does NOT come on but it never did even when the fogs were working before, I just know if its on if the button is in or if the button is out.
And yea I've replaced the bulbs before and yea everytime I hate it....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by japspecjohn »</TD></TR><TR><TD CLASS="quote">extra weight
lol @ hate.
</TD></TR></TABLE>lol @ hate.
hmmm thats funny I dont remember saying that weird...I like EK fogs
</TD></TR></TABLE>hmmm thats funny I dont remember saying that weird...I like EK fogs
Guest
Posts: n/a
Ok anyways, besides the guy who is obviously schizophrenic;
Anyone have an idea where the fuse is? (once again not located in the manual)
</TD></TR></TABLE>Ok anyways, besides the guy who is obviously schizophrenic;
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1Guru »</TD></TR><TR><TD CLASS="quote">i thought there was a 15 amp fuse on the wire harness.
the foglight button, does it still light up?</TD></TR></TABLE>
Ahh fuse ON the harness ehh?
And the button doesn't light up.
But it hasnt lit up even when the fogs were on.
Thanks.
Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Louie_EM1 »</TD></TR><TR><TD CLASS="quote">
Thanks.</TD></TR></TABLE>
yes, there is a fuse on the harness i believe.
that is odd that the little led light on the button does not turn on.
i would make sure that everything is plugged in correctly. foglight harness, switch harness.
Guest
Posts: n/a
i would make sure that everything is plugged in correctly. foglight harness, switch harness. </TD></TR></TABLE>
Red?! Thought it was green.
Red?! Thought it was green.</TD></TR></TABLE>
Read more closely, he said LED, not Red.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Louie_EM1 »</TD></TR><TR><TD CLASS="quote">Ok anyways, besides the guy who is obviously schizophrenic;
Anyone have an idea where the fuse is? (once again not located in the manual)</TD></TR></TABLE>
zip it Nooooob........or I left my name logged in on one of my other computers and another honda-tech user in the house hold wrote it.
During lunch, I will check if/where there is a fuse on the inline harness (my fogs are still in the box)
EDIT - i have the installation instructions here at work IM me if you want a copy (email/fax) there is an inline fuse underneath the dash (should be near the relay which is bolted tp the ground another connection you should check)
SEE INSTRUCTIONS HERE
http://www.handa-accessories.c...s.pdf
PAGE 8 - shows were you can find the inline fuse
also shows how to change the bulb without removing the bumper
Modified by adirondackR at 8:44 AM 3/15/2004
Guest
Posts: n/a
zip it Nooooob........or I left my name logged in on one of my other computers and another honda-tech user in the house hold wrote it.</TD></TR></TABLE>
Accutally, I've been a member for longer than you.
This name was made on my birthday.
Isn't it easy to talk the trash behind a keyboard?
It's your fault that you left it logged on.
Not only that; have you ever taken the time to read the rules.
It's morons like you that decay this forum. If you don't got **** to say shut the **** up, move on.
Do not reply back for you're bandwitdh and life are a waste
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adirondackR »</TD></TR><TR><TD CLASS="quote">During lunch, I will check if/where there is a fuse on the inline harness (my fogs are still in the box)
Modified by adirondackR at 8:44 AM 3/15/2004</TD></TR></TABLE>
Thanks man.
Im going to take apart the lower dash on the drivers side see if I can find a blown fuse directly behind the button.
Thanks man.
