engine swap s2000
Old Mar 14, 2004 | 08:13 AM
.:Swig:.'s Avatar
Default engine swap s2000
yeah is it possible to install an s2000 motor in a 2000 civic???
Old Mar 14, 2004 | 09:19 AM
GOLDBERG's Avatar
Default Re: engine swap s2000 (greenjdmcivic)
almost anythingis possible
Integ03's Avatar
Anything is possible i could mount a b18c motor on my skateboard if i had the money but the question is WHY?
Old Mar 14, 2004 | 12:47 PM
93ludeSi's Avatar
Default Re: (Integ03)
killer first post.
I think the biggest problem is getting a tranny to work
Old Mar 14, 2004 | 01:24 PM
Dual Cams's Avatar
Default Re: (93ludeSi)
quick question clay smith cams??? the one from CA?
Old Mar 14, 2004 | 01:36 PM
Relix H22a1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ludeSi &raquo;</TD></TR><TR><TD CLASS="quote">killer first post.
I think the biggest problem is getting a tranny to work</TD></TR></TABLE> Therre you go? I'm not aware of anyone making a fwd tranny for that engine as of now(but I could be wrong) Also the engine mounts them selves are in the wrong spots for a transvers(SP) mounted engine... Good luck pulling that off though!
Old Mar 14, 2004 | 01:48 PM
alloutmotor's Avatar
well actually i have heard from word of mouth..i have no facts on this nor have i seen it done...but i have heard that the s2000 motor does bolt up to the rsx transmission.....
and if u had a 2001+ civic you probably could use the entire sub frame from a rsx and swap the motor in....but since hasport is coming out with a kseries mounts to go into 6th generation civics that may work..or require some modifications....all this stuff is fairly new...in a couple of years motors will be cheaper and more people will have time to play with them
Old Mar 14, 2004 | 06:39 PM
93ludeSi's Avatar
Default Re: (Dual Cams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dual Cams &raquo;</TD></TR><TR><TD CLASS="quote">quick question clay smith cams??? the one from CA?</TD></TR></TABLE>
yes sir, Buena Park, but those cams are comming out soon, the have a 285 duration, so the idle is not all that streetable
Old Mar 14, 2004 | 07:03 PM
eyeamvic's Avatar
Got money?
spoon_concept_eg6
18
Mar 24, 2008 06:55 AM
artifex
Oct 2, 2006 05:30 PM
kb58
Honda S2000
12
Oct 17, 2005 01:14 PM
bigz187
May 25, 2005 06:41 AM
JoeBurton11
Honda S2000
Oct 25, 2004 07:07 AM
