Need to change valve springs with Toda A camshafts?
Old Mar 14, 2004 | 04:52 AM
Edward's Avatar
Default Is Toda A cam need to change valve spring?????
I have already install Toda A cam. Do i need to change Valve spring?? If i don't change, what's happen in the future. Thanks a lot!!
Old Mar 14, 2004 | 04:56 AM
Misfit's Avatar
Default Re: Is Toda A cam need to change valve spring????? (Edward)
I don't think so.. Just don't go over the stock rev limiter to be on the safe side.
Old Mar 14, 2004 | 05:47 AM
shane01itr36's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misfit &raquo;</TD></TR><TR><TD CLASS="quote">I don't think so.. Just don't go over the stock rev limiter to be on the safe side. </TD></TR></TABLE>
You are correct!!!
http://www.todaracing.com/prod....html
Old Mar 14, 2004 | 12:53 PM
Black R's Avatar
25 Year Member
I have toda a's in my itr. Stock itr valvetrain is fine.
If you will be going over 9200 rpm, then you might want to upgrade the valvetrain.
Awesome cams.
Old Mar 14, 2004 | 07:48 PM
NSXjr's Avatar
Default Re: Is Toda A cam need to change valve spring????? (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">I have toda a's in my itr. Stock itr valvetrain is fine.
Awesome cams. </TD></TR></TABLE>
THats wut i herd too.. "Stock itr valvetrain is fine"
Old Mar 14, 2004 | 07:53 PM
H-PIMP's Avatar
No
Old Mar 14, 2004 | 08:42 PM
Black R's Avatar
25 Year Member
http://filebox.vt.edu/users/echi/todaa.JPG
VTHokie's plots on drop in and then with tuning..... I'll try to find a stock itr plot for comparo's sake.....
Old Mar 14, 2004 | 09:03 PM
Black R's Avatar
25 Year Member
found a stock itr dyno plot on the same dyno. Thanks to jack:
http://p1auto.com/forum/viewto...7500e
JDM97dc2R
Dec 29, 2005 09:15 AM
HONDA RR
Nov 5, 2004 09:54 AM
tech6804
Oct 5, 2004 04:00 PM
mrtrex
Jul 27, 2004 10:33 PM
powerfulperformance
May 5, 2002 05:16 PM
