energy suspension motor mount inserts
Old Mar 14, 2004 | 03:57 AM
a1320honda's Avatar
Default energy suspension motor mount inserts
ive got real bad wheel hop, and was told these would help a ton as well as with firmer shifts and all the other hooplaa. does anyone run these, do they work, i know there only like 35-40 bucks. so why not i guess? anyone?
Old Mar 14, 2004 | 05:18 AM
saleensolution's Avatar
Default Re: energy suspension motor mount inserts (a1320honda)
i had some but they really dont stop the wheel hop effect. looks like you have 92-95 civic from your avatar i would invest in a jim fab front cross member that will eliminate your hop
Old Mar 14, 2004 | 05:32 AM
shermanyang's Avatar
Default Re: energy suspension motor mount inserts (saleensolution)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saleensolution &raquo;</TD></TR><TR><TD CLASS="quote">i had some but they really dont stop the wheel hop effect. looks like you have 92-95 civic from your avatar i would invest in a jim fab front cross member that will eliminate your hop</TD></TR></TABLE>
i've heard that those front cross member bars work wonders...but that they also cause a clearance issue with exhaust/downpipes. i was looking to get one of those as well as the inserts just to see for myself what really helps.
Old Mar 14, 2004 | 05:39 AM
tilt's Avatar
I didnt have a problem with wheel hop before installing inserts, but it did help eliminate lurching when letting off the gas. The only downside imo is the extra vibration you will feel while idling at a stop light.
Old Mar 14, 2004 | 06:51 AM
georgelb's Avatar
Default Re: energy suspension motor mount inserts (tilt)
I installed the prothane ones and they did not dramatically help with wheel hop. The shifts were indeed improved though. I did not feel the benefits were worth the horible vibration in my daily driver so I took them out.
Old Mar 14, 2004 | 07:18 AM
. o 69 o .'s Avatar
Default Re: energy suspension motor mount inserts (georgelb)
I have them, I like em. For $40 its worth a shot, it might help.
Old Mar 14, 2004 | 07:31 AM
gloryhog's Avatar
shake like crazy, I felt a great improvement in my shifts, the back one is a bitch to put in.
Old Mar 14, 2004 | 09:02 AM
Team 4R's Avatar
the torque mount inserts are meant to stabilize your motor during shifting and acceleration, not reduce your wheelhop....... to cut the wheelhop you'll need to upgrade your upper driver and tranny side mounts..... or you could get adjustable shocks for the front and set them to soft.
Old Mar 14, 2004 | 09:52 AM
. o 69 o .'s Avatar
Default Re: energy suspension motor mount inserts (Team 4R)
or get Z-10 radius Rods
nah22accord
Apr 20, 2006 08:27 AM
elitesi8
Oct 9, 2005 06:42 AM
Hybrid96EK
Feb 9, 2005 11:16 PM
flashmang
Oct 11, 2004 09:11 PM
