Speedometer not working?
Old Oct 18, 2001 | 07:18 PM
PorscheGT2's Avatar
New User
Default Speedometer not working?
I have a 91 accord ex, my speedometer doesn't work and my sport light is flashing and the check engine light is on, whats going on with my car? Is it something easy to fix, or does a professional nees to look at it? Thanks.
Old Oct 19, 2001 | 07:50 AM
4doorH22's Avatar
Default Re: Speedometer not working? (PorscheGT2)
What is a sport light?
Old Oct 19, 2001 | 02:36 PM
dvsOasis's Avatar
90-91 accords have a sports shift...if you push the button to activate it, the transmission will shift at a higher/later rpm...rather than shifting as soon as possible...
With that in mind, I would think that the sports shift light is blinking because it can't get a reading from the speedometer (so it can determine when to shift)...
since your check engine light is on, there should be a code in the ECU...check with a haynes manual, pull the code out of the ECU, and that should tell you what's wrong
screammy
Aug 12, 2009 02:39 PM
JDMishEK
27
Aug 23, 2007 08:29 AM
hcic
Jun 7, 2007 07:27 PM
joej
Mar 8, 2004 05:58 PM
Caramel Turtle
Dec 27, 2002 04:07 AM
