another axle question about b-series CRX (I know, I know...)
Old Mar 14, 2004 | 12:42 AM
Mr_CRX's Avatar
Default another axle question about b-series CRX (I know, I know...)
YES i searched, but was still confused..
So I bought my GSR swap and it came with a 94+ intermediate shaft. I need confirmation that 94+ teg axles will work in my swap? Everyone says to use 90-93 teg axles but the guy i got the swap from apparently had it in a crx before. Im just thinking I can save money if I dont need to buy a new intermediate shaft..
please let me know, thanks!
Old Mar 14, 2004 | 12:54 AM
civickiller's Avatar
Default Re: another axle question about b-series CRX (Mr_CRX)
yes you can use 94+ teg axles with intermediate shaft but if you are using a cable tranny then you gotta change the tranny axle seal with 94+ teg, same if you wanted to use 90-93 teg axles with your hydro you would need to change the seal to 90-93
Old Mar 14, 2004 | 01:17 AM
Fobtions's Avatar
Default Re: another axle question about b-series CRX (civickiller)
ive been using the 94-up midshaft for 3 years on my b18c crx. just ask for a 94-up midshaft seal.
also make sure u remove everything on the hub portion of the axle.
since u are in san diego, there is a good place in convoy that has lifetime warranty axles that are way better than the autozones. onestop undercar.
Old Mar 14, 2004 | 04:03 AM
silverCRXTC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">yes you can use 94+ teg axles with intermediate shaft but if you are using a cable tranny then you gotta change the tranny axle seal with 94+ teg, same if you wanted to use 90-93 teg axles with your hydro you would need to change the seal to 90-93</TD></TR></TABLE>
Couldn't put it better my self.
wpgcivic
11
Feb 25, 2007 11:21 AM
95_red_dc
Apr 24, 2006 07:02 AM
88ED8
Apr 30, 2005 09:35 AM
allmotorlsvtecrx
Feb 19, 2004 06:58 AM
EsQueue
Oct 8, 2003 05:57 PM
