H&R race spring help...
Old Mar 14, 2004 | 12:04 AM
2 point 0's Avatar
Default H&R race spring help...
just installed H&R race springs on my 96 hatch. i bought a set of used springs so they should'nt settle. my friend has the same springs on his EK but the tires are tucked. mine has a 1 finger gap. is there any way i can make mine a little lower?
Old Mar 14, 2004 | 12:36 AM
BI8B's Avatar
Default Re: H&R race spring help... (2 point 0)
maybe he's running different shocks.
Old Mar 14, 2004 | 10:59 AM
2 point 0's Avatar
Default Re: H&R race spring help... (BI8B)
do shocks really make a difference?
Old Mar 14, 2004 | 11:09 AM
jerbear!'s Avatar
koni yellows add like a .5 inch drop, right?
Old Mar 14, 2004 | 11:14 AM
Navid OG's Avatar
Default Re: (jerbear!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerbear! &raquo;</TD></TR><TR><TD CLASS="quote">koni yellows add like a .5 inch drop, right?</TD></TR></TABLE>
yup... Koni's can add .5" drop
Old Mar 14, 2004 | 11:15 AM
North_Texas's Avatar
I have Neuspeed Race springs (used). Had them on for like 4-5 Months now and I
have them almost tucking. But I am riding on blown stock shocks and 14"
steelies. Also let time go by they will sag some more cause my sure did. When
lowering my car it was 2" drop all the way around now with or after riding with 5
ppl in my car the other day, it has lowered 2.25" all the way around. Sorry but
just posting my .02, so I hope that helps.
Alex
Old Mar 14, 2004 | 11:18 AM
743's Avatar
743
I bought my neuspeed race springs used and they settled in quite a bit. Just give them some time.
Old Mar 14, 2004 | 11:23 AM
2 point 0's Avatar
Default Re: H&R race spring help... (-743-)
are the koni yellows the only shocks that provide a little more drop? what about KYB AGX or tokico illuminas? i thought since there are settings on them, that'll effect the drop somehow.
Old Mar 14, 2004 | 11:28 AM
onefstek's Avatar
did u cut the bumper stops, you might be riding on them. ??? 98ctr
Old Mar 14, 2004 | 11:29 AM
aw1234dude's Avatar
Did you remember to cut the bump stops. I have the H&R races also and I cut two of the top ribbed sections off (basically cutting them in half) and I dont have any wheel gap.
Old Mar 14, 2004 | 11:51 AM
2 point 0's Avatar
Default Re: H&R race spring help... (aw1234dude)
yeah, the bumpstops are cut. any other advices?
Old Mar 14, 2004 | 12:23 PM
onefstek's Avatar
how low is the front comparing to the rear?
Old Mar 14, 2004 | 07:03 PM
2 point 0's Avatar
Default Re: (98ctr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98ctr &raquo;</TD></TR><TR><TD CLASS="quote">how low is the front comparing to the rear? </TD></TR></TABLE>
both are about the same. 1 finger gap. except for the rear passenger...it's about 2 finger gap.
Old Mar 14, 2004 | 08:12 PM
onefstek's Avatar
Default Re: (2 point 0)
raise the car up and make sure that the spring is seated right. You should be able to turn the spring clockwize untill it seats properlly. That might be your proble. 98ctr
Old Mar 15, 2004 | 10:19 PM
2 point 0's Avatar
Default Re: (98ctr)
everything is seated properly. how can i get the rear passenger even?
Old Mar 16, 2004 | 01:41 AM
LCheung's Avatar
That's an odd problem. Koni yellow actually have a few height settings, the entire perch comes off and you can change it to like 3-4 heights.
I had H&R on my CRX long ago, but it left like 2 finger gap on the front and 1 in the rear, I ran it on KYB AGX struts and stock structs. Resulted in the same height.
Despite the new or used springs, the height should settle. It's not just the springs that sag a bit, the other parts in the car also need time to settle. You may notice your car is a little taller after you jack it up to work on it, it's the same idea.
One wheel gap is larger than the others... hmmm not sure on this one. Go have the car aligned? If the arms on that one corner is significantly out of alignment it could cause it to have a "different height."
-Leon
Old Mar 16, 2004 | 12:59 PM
hondatuner99's Avatar
I have H&R race on my EK hatch, and it tucks the tires all the way around! But, i have a prob, mine is too low, it already put the upper control arms through the strut towers, so go figure! I'm thinkin about gettin H&R sport springs this summer!
Oh, and i'm using stock struts!
Hondatuner99
honda305
Suspension & Brakes
Feb 23, 2010 09:59 AM
felixjr18
Suspension & Brakes
22
Apr 24, 2009 01:23 PM
dc2955556
Suspension & Brakes
Jul 8, 2006 04:48 AM
fiebru1119
Mar 26, 2006 02:48 PM
CiViC dRaGsTaR
11
Jul 13, 2001 12:37 PM
