A slide on brake caliper bracket is stuck, any help
Old Mar 13, 2004 | 09:56 PM
pbcdb's Avatar
Default A slide on brake caliper bracket is stuck, any help
So as I was doing my brakes I noticed that a slide on one of the brake caliper bracket was stuck. Is there any way to get this out or should I get a new part.
Old Mar 13, 2004 | 10:26 PM
SiFan's Avatar
Default Re: A slide on brake caliper bracket is stuck, any help (pbcdb)
Are you asking about the sleeve the bolt slides through?
Old Mar 13, 2004 | 10:31 PM
pbcdb's Avatar
I am talking about one of the caliper pins that slided in the caliper bracket. Ya know the ones with the little rubber dust covers on them.
aw1234dude's Avatar
Default Re: A slide on brake caliper bracket is stuck, any help (SiFan)
Are you talking about number 17 and 18 in this picture
The sleeve might just be rusted and siezed to the bolt. If you can you might try to pull the bolt out to see if the sleeve is still good and if it is maybe you can just get a new bolt and sand down the sleeve a little.
Old Mar 13, 2004 | 10:34 PM
pbcdb's Avatar
My bad it is on the rear caliper too if that helps at all. And it isn't a bolt. It is a caliper pin.
Old Mar 13, 2004 | 10:48 PM
SiFan's Avatar
Default Re: (pbcdb)
How about you describe your removal procedure? I don't think I've ever head of one just strait up stuck. You remove one bolt rotate the caliper down an slide it off. If you didn't roll it down far enough it wont clear the pads an seem stuck. If it doesn't move at all for what ever reason try some......penetrating oil?
Old Mar 13, 2004 | 10:55 PM
mantic6t9's Avatar
Default Re: (SiFan)
Hmm are you sure.. I don't remember ANY pins on the rear calipers on my si hatch..
Old Mar 13, 2004 | 10:56 PM
pbcdb's Avatar
Ya man rear calipers are differant. For rear calipers you take off the two bolts connecting the caliper to the caliper bracket and then just take it off. Then to get rotors off you need to take the caliper mounting braket off so I took that off. Then when I was going to clean the caliper pins, which are housed in the caliper mounting bracket, I noticed that one of them was stuck.
pbcdb's Avatar
The pins are in the caliper mounting bracket not the caliper itself.
Old Mar 13, 2004 | 11:13 PM
mantic6t9's Avatar
Default Re: (pbcdb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pbcdb &raquo;</TD></TR><TR><TD CLASS="quote">The pins are in the caliper mounting bracket not the caliper itself.</TD></TR></TABLE>
Oh ok........
Old Mar 13, 2004 | 11:21 PM
SiFan's Avatar
Default Re: (pbcdb)
Sorry a little tired on this end! Leave the pin in an apply a generous amount of anti-seize to it, the caliper just slides on it, it doesn't move itself.
Old Mar 13, 2004 | 11:26 PM
pbcdb's Avatar
Ya I think I just need a new bracket and pins, cause my friend was telling me that the pin will just lock into place cause of the extreme heat of breaks and the lack of lubrication that was probably on there. He went on to say that even if I could break it out the place were the pin was housed would not be ideal to use again. Thanks for trying to help anyways.
Old Mar 13, 2004 | 11:28 PM
pbcdb's Avatar
ya on the rear calipers these pins slide in and out of the caliper mounting bracket.
Old Mar 13, 2004 | 11:30 PM
SiFan's Avatar
Default Re: (pbcdb)
Guess I was looking at the pic wrong! sorry!!! Good luck!!!!!!!!!!!
Old Mar 13, 2004 | 11:35 PM
pbcdb's Avatar
No, you weren't looking at the pic wrong, but the pic is of a front caliper the rear calipers are differant.
Old Mar 14, 2004 | 02:12 PM
voltageGSR's Avatar
Default Re: (pbcdb)
i was chaging rear brakes today -
can't push the piston back in; how the heck do it
reload it?
also can't seem to get the rotor retaining screws out...don't have
impact screwdriver; any ideas?
just not a good day..thanks.
Old Mar 14, 2004 | 02:14 PM
Ricey McRicerton's Avatar
Default Re: (voltageGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by voltageGSR &raquo;</TD></TR><TR><TD CLASS="quote">i was chaging rear brakes today -
reload it?
just not a good day..thanks.</TD></TR></TABLE>
The rear pistons turn (as if to screw in).
Old Mar 14, 2004 | 02:20 PM
voltageGSR's Avatar
Default Re: (Ricey McRicerton)
i tried using a large vice grip to turn
it wouldn't turn
its not frozen though; it does move a with emergency brake..
but i can't get it pushed in - it sticks out about 2 cms.
Old Mar 14, 2004 | 02:21 PM
voltageGSR's Avatar
what do i turn it with ?
also; can't get teh stupid brake rotor screws off
friend said use impact screw driver but don't have one
any other ideas?
The rear caliper has a + on it. Get a screwdriver or something long and thin, and use it to screw it down (can't remember which direction, but you should be able to see it going in or out).
Old Mar 14, 2004 | 02:36 PM
pbcdb's Avatar
Allen wrench work for me to compress the piston. And the direction is clockwise.
Old Mar 14, 2004 | 02:43 PM
voltageGSR's Avatar
Default Re: (pbcdb)
used a thin screwdriver - clockwise...
spun right in! thanks guys...
any ideas hot to get the rotor off...no impact screwdriver..
7pm on sunday..sears closed..
splitime's Avatar
Default Re: (SiFan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiFan &raquo;</TD></TR><TR><TD CLASS="quote"> Sorry a little tired on this end! Leave the pin in an apply a generous amount of anti-seize to it, the caliper just slides on it, it doesn't move itself.</TD></TR></TABLE>
Do NOT use anti-seize. That stuff gets gunky and think in 0 time flat. You'll want to remove the pin, i used lock plyers and a hammer. Then clean it up some, also try to clean the bracket it slides in. Then use a good high-temp grease, honda has a specific grease in their rebuild kits.... not sure what it is but at the minimum use a high temp grease. Then put the stuff back together.
Old Mar 14, 2004 | 02:51 PM
pbcdb's Avatar
Ya I let it sit overnight with alot of penetrating liquid on it, then I was able to use a open ended wrench and a hammer to pound it out. Then I let some penetrating liquid sit inside the hole on the bracket and that along with break cleaner cleaned it out very well. Then I just got new pins.
Patty
Mar 7, 2009 08:12 AM
mattsnooz
Jun 29, 2008 09:03 AM
HumanResource
Feb 21, 2007 07:52 AM
dasistheone
Apr 15, 2006 01:35 PM
