02 sensor removal help...
Old Mar 13, 2004 | 09:09 PM
stryderlis's Avatar
Default 02 sensor removal help...
I was trying to change the primary o2 sensor today and that this is on tight as hell. Any tips on how to remove it? There's not much room to work with under there either. I don't have any power tools and i'm only using a 22mm wrench to try to remove and which is not doing much. If I can't change it tomorrow i'll just take it to a muffler shop, any idea how much it'll cost for them to just remove and put on the o2 sensor i already have.
Old Mar 13, 2004 | 09:13 PM
Filliam H. Muffman's Avatar
Default Re: 02 sensor removal help... (stryderlis)
you are now asking honda-tech how to take off a bolt.
Simple solutions:
1)go to the gym.
2) get a breaker bar
3) go find a girl who can do it, because apparently its on too tight for you.
4) hide under a rock and save yourself the embarassment
but in all seriousness, just try harder.
Old Mar 13, 2004 | 09:17 PM
aw1234dude's Avatar
Default Re: 02 sensor removal help... (JUN EK9)
Ha ha BURN...... If you aren't afraid to risk rounding the O2 sensor you can take the wrench and put it firmly onto the sensor and tap on the end of the wrench with a mallet. If you hit it hard enough it should loosen it enough for you to spin it off. Seriously get stronger.....
Old Mar 13, 2004 | 10:31 PM
Cheivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN EK9 &raquo;</TD></TR><TR><TD CLASS="quote">you are now asking honda-tech how to take off a bolt.
Simple solutions:
1)go to the gym.
but in all seriousness, just try harder.</TD></TR></TABLE>
ROFL. Spray some WD 40 on it, let it sit for 2 minutes. Get a rubber mallet and hit your wrench like dude said. If that's not enough, get a metal pole or breaker bar and use it for leverage. Leverage is your friend in these situations.
Old Mar 13, 2004 | 10:42 PM
Unjockable's Avatar
New User
Default Re: 02 sensor removal help... (Cheivic)
they sell a socket made to take off the O2 sensor. has a little slit on the side.
Old Mar 14, 2004 | 12:02 AM
cruz78727's Avatar
dont use an 02 socket they are ****, break off the end of the sensor and use a regular socket and ratchet or breaker bar
problem solved
Old Mar 14, 2004 | 01:28 AM
Unjockable's Avatar
New User
Default Re: 02 sensor removal help... (cruz78727)
the O2 sensor socket is made for a reason. why the **** would you break off your own sensor and use a regular socket? dumbasses nowadays.
Old Mar 14, 2004 | 01:34 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: 02 sensor removal help... (Unjockable)
yeah exactly. you use the right tool for the right job.
Old Mar 14, 2004 | 03:28 AM
WalkingKenshin
Guest
Posts: n/a
well your first post on h-t, and you show how ******* stupid you are.
right tool for the job.
ps. back to the orginal post.. LMAO it's a ******* o2 sensor bro... wd40, wrench, ******* breaker bar.. anything.
ajholt7
Jul 31, 2011 06:31 PM
EG-SIXV-TEC
Feb 7, 2009 01:14 PM
shbrown
Mar 1, 2006 02:58 PM
cvc323
12
Nov 17, 2004 11:46 AM
JDMDC5888
Mar 25, 2004 02:36 PM
