what kind of times can i lay down
i have a 88 hf with a b18a1 that is being built right now. and i was wondering what you guys thought i will run with 210hp, and what i would run when i spay it with a 100 shot of juice that should put me arround 300hp after tunning. im running a LS tranny. my budget didnt let me change the tranny out. SO! what do you think? will it make me proud, and run sum high 11's or low 12's when i spray it?
yeah right y94crxsi, i was running 14 flat with a ls set up, street tires, and a 75 shot on 2nd and up gears. the motor at that time had 170 thousand miles on it so it was far past due for a rebuild. i know i will run better than 16's. and as for the suspention and tires. i have coil overs from my teg on it so the spring rate is very stiff for the car and the tires im not sure yet. i will probly get slicks mounted on the Rota wheels i just bought. i want 11's so bad. im going with spray because i already had it and didnt have it in my budget to get a turbo kit for the car.
yeah right y94crxsi, thats bull **** lol, i was running 14 flat with a ls set up, street tires, and a 75 shot on 2nd and up gears. the motor at that time had 170 thousand miles on it so it was far past due for a rebuild. i know i will run better than 16's. and as for the suspention and tires. i have coil overs from my teg on it so the spring rate is very stiff for the car and the tires im not sure yet. i will probly get slicks mounted on the Rota wheels i just bought. i want 11's so bad. im going with spray because i already had it and didnt have it in my budget to get a turbo kit for the car.
South Bay Surfer
13
Jul 2, 2008 07:53 AM
DIRep972
Dec 2, 2002 10:37 AM
DIRep972
Oct 11, 2001 06:20 AM
