ARP rod bolts and head studs, worth it w/ my lsvtec?
Old Mar 13, 2004 | 07:07 PM
ls95hatch's Avatar
Default ARP rod bolts and head studs, worth it w/ my lsvtec?
worth it or not?
building motor w/
crower stage 2 valvetrain
ctr over sized pistons
ls rods
cometic head gasket to lower compression for drivability
and other jibba jabba that shouldnt make or break the decision
i know alot of people use the arp rod bolts and head studs, but i am just wondering if it really matters? anyone w/ experince? thanks
Old Mar 13, 2004 | 07:39 PM
zensoku207's Avatar
Hell yeah.
Especially after running higher comp pistons such as ctr's. Arp's will hold the head tight, where as stock ones may stretch.
Rod bolts are a good idea too, a lot of people shotpeen the stock rods and they work fine. But with higher revving vtec head, rod bolts won't snap like oem ones do.
Old Mar 13, 2004 | 08:26 PM
00 FBP ItR's Avatar
Default Re: ARP rod bolts and head studs, worth it w/ my lsvtec? (ls95hatch)
Yes very worth it, esp. if you plan on revving to 8k+.
I'd also recommend getting the rods notched for gsr bearings.
Old Mar 14, 2004 | 06:27 AM
b19coupe's Avatar
It matters. Get the stronger rod bolts and head studs.
Old Mar 14, 2004 | 02:16 PM
ls95hatch's Avatar
Default Re: ARP rod bolts and head studs, worth it w/ my lsvtec? (b19coupe)
thanks guys, i really didnt want to spend the money but it seems to be a must have.
Old Mar 14, 2004 | 04:02 PM
99lsvtecauto's Avatar
the arp rod bolts are 35 shipped @ lightning motorsports and they should have the headstuds they r like a hundred special for ht member rod bolt part # 208-6001
Old Mar 14, 2004 | 08:20 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: ARP rod bolts and head studs, worth it w/ my lsvtec? (99lsvtecauto)
when u do an Ls vtec , do u use ls head studs or gsr head studs?
Old Mar 14, 2004 | 08:49 PM
Dan GSR's Avatar
Default Re: ARP rod bolts and head studs, worth it w/ my lsvtec? (BLUE EH3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">when u do an Ls vtec , do u use ls head studs or gsr head studs?</TD></TR></TABLE>
gsr
Old Mar 15, 2004 | 04:39 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: ARP rod bolts and head studs, worth it w/ my lsvtec? (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">
gsr</TD></TR></TABLE> why wouldnt use LS head bolts? gsr bolts are to short for a LS block
Old Mar 15, 2004 | 04:49 AM
Dan GSR's Avatar
b18a, b18b, b20b, b20z
with any vtec head, you use gsr/itr head studs
Old Mar 15, 2004 | 04:55 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote"> why wouldnt use LS head bolts? gsr bolts are to short for a LS block </TD></TR></TABLE>
The head is what determines the head bolts that you need. The bolt length is based on the height of the head.
Old Mar 15, 2004 | 05:00 AM
Dan GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">
The head is what determines the head bolts that you need. The bolt length is based on the height of the head.</TD></TR></TABLE>
yes, but don't forget to mention, that you don't use b16 bolts with a 1.8 bottom
ppl may get confused, and think b16 head, i'll use b16 bolts
Old Mar 15, 2004 | 01:13 PM
ls95hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99lsvtecauto &raquo;</TD></TR><TR><TD CLASS="quote">the arp rod bolts are 35 shipped @ lightning motorsports and they should have the headstuds they r like a hundred special for ht member rod bolt part # 208-6001 </TD></TR></TABLE>
is that just lightingmotorsport.com? good pricees. thanks for the help guys
Old Mar 15, 2004 | 04:58 PM
yey that lightningmotorsports.com u may possiblely see them as an advertised company at the top of screen or if u do a search thru archived links on ht type in arp rod bolts they should come back in sponsored marketplace anytime with the help help can b scarce on ht depending on the topic
Old Apr 10, 2004 | 05:37 PM
kcalb_3pe's Avatar
Default Re: ARP rod bolts and head studs, worth it w/ my lsvtec? (00 FBP ItR)
what good will it do to get your rods notched for gsr bearings....why not stick with stock ls???????
Old Apr 10, 2004 | 06:58 PM
i think it is lightningmotorsports but if u just type there name in a ht search they r a sponsor to my understanding people renotch for gsr rods and bearing because the are wider so supposedly should take more abuse not certain can some 1 confirm or deny
swapped95
Sep 21, 2007 07:34 PM
hybrid2007
May 19, 2007 12:53 PM
akura404
Mar 3, 2006 02:12 PM
TwoPointZero
Apr 5, 2004 07:29 PM
ranta18
Sep 1, 2003 01:00 PM
