what timming belt and water pump for a dohc zc
well i was going to say you cant tell him to search because your a n00b, but you have 29days under your belt so i'll let it slide
anyway i think you need a 88-89 Integra pump and belt
haha..yeah thanks bro.
i dedicate this one to Honda-Tech.com for thier help by supplying us with the search button. I searched and found some useful information that linked me to
thezcr.com the site that has all your ZC needs.
anyways...this should help
What are some cheap mods I can do to provide modest gains?
· What should I replace before I install my ZC motor?
· What ECU should I use with my DOHC ZC?
· Getting a code 7. How do I adjust the TPS?
· My check engine light came on. How do I check to see what is wrong?
· How do I find out what year my DOHC ZC was made?
· How much does my DOHC ZC motor weigh?
· What are the common L3 transmission Gear Ratios?
· What are the valve adjustment specifications for the ZC?
· I am getting a Code 9. What do I do?
· What ARP head studs do I get for the ZC?
more zc info here: http://www.thezcr.com
come on over to thezcr.com Almost everyone have the same motor.
You can use a water pump from an 89 Integra.
for your Timing belt, you'll need one from a 1988 Honda Prelude SI
crxzcracer
Mar 30, 2004 12:28 AM
90hatchsi
Feb 26, 2004 03:22 PM
