acceleration hesitaion?
Old Mar 13, 2004 | 06:26 PM
kwik92hb's Avatar
Default acceleration hesitaion?
my rebiuld is complete,d16z6 with je 11.5to 1 comp,skunk 2 intake manifold,hondataim gasket,comptech springs,retainers and .5 mm oversized valves.started car today for first time and runs fine.idles fine but when u accelerate it stumbles a second then picks right up,any input would be awesome
Old Mar 14, 2004 | 05:38 AM
doublejz's Avatar
Default Re: acceleration hesitaion? (kwik92hb)
check your timing, did the same thing to me before
Old Mar 14, 2004 | 01:24 PM
kwik92hb's Avatar
Default Re: acceleration hesitaion? (doublejz)
thanx was it cam gear or dist,that u had ur problem with?thanx for the reply
Old Mar 14, 2004 | 01:56 PM
doublejz's Avatar
i think my distributor was retarded the whole way, i think
Old Mar 15, 2004 | 11:58 AM
tgreaves's Avatar
Check the adjustment on your tps sensor.. Might be off, It should be .45 volts no pressing the gas and 4.5 volts with the gas floored.. Check the voltage at the center tps wire and the chassis ground..
Old Mar 16, 2004 | 06:02 PM
PnX-R's Avatar
Stumbles?.. Do you mean accel - stop accel - then continues to accel again?..
Maybe there's a skip or dead spot in your TPS..
stocker2shocker91
Apr 27, 2014 04:55 PM
90crxef
Engine Management and Tuning
Apr 23, 2008 05:38 PM
BLU CIVIC
Sep 17, 2007 08:13 PM
Phrost
46
Sep 3, 2006 10:47 PM
c1civic
Apr 4, 2004 06:15 PM
