Help with emissions
Old Mar 13, 2004 | 05:22 PM
97blueteg's Avatar
Default Help with emissions
Just a quick question. I'm in the CT area and will soon be done with my boosted ls motor, however i'm worried about emissions. Does anyone know where i can be passed or is there a way i can rig it so that i won't fail? I just had it done on my stock motor a little while ago and i want to make sure i will not run into any trouble. Any help would be great.. Thanks.
Old Mar 13, 2004 | 07:50 PM
Undercover_Skank's Avatar
You can't pass with a boosted motor. You can either cheat smog or pay someone under the table or return everything back to stock.
Old Mar 14, 2004 | 07:22 PM
tolstiy1980's Avatar
Default Re: Help with emissions (97blueteg)
i work at emmisions and i got a question to you does your car have obd2?
Old Mar 14, 2004 | 07:40 PM
svtec's Avatar
L D E S
Default Re: Help with emissions (tolstiy1980)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tolstiy1980 &raquo;</TD></TR><TR><TD CLASS="quote">i work at emmisions and i got a question to you does your car have obd2?</TD></TR></TABLE>
if it does you may have issues.
Old Mar 14, 2004 | 09:42 PM
97blueteg's Avatar
My car is OBD II b/c it's a 97.. However i'm doing a stand alone fuel management and i swapped my ecu out for a 95 civic which is obd1. I'm trying to see if there is a way around me failing emissions or if anyone would be able to "pass me". Rather get this all taken care of ahead of time before i get the motor all set up and then find trouble later on.
killakalipoph
Feb 1, 2010 04:48 AM
littlej72
Mar 13, 2008 02:08 PM
ej8_vtec
Nov 3, 2006 01:39 PM
Mr. JDM-GSR
Feb 7, 2006 12:30 PM
bigbacon2
Oct 24, 2004 12:57 PM
