Anyone with 4.78 ITR Final drive in there GSR
Old Mar 13, 2004 | 02:52 PM
ctrcivic's Avatar
Default Anyone with 4.78 ITR Final drive in there GSR
Anyone with a 4.785 ITR final drive in their GSR? How much did it raise your rpm in 5th? Has anyone put in the LS 5th gear with the install. How does the gear ratios compare with the 98 spec ITR? Also please give me a website I can order the kit that comes with everything that I'll need to do the install. I'm assuming the final drive kit will work with the ITR or CTR LSD right?
Thanks
Old Mar 13, 2004 | 02:57 PM
Kendall's Avatar
Easy there killer. When getting into trannies, you have to consider cost and function. Taking a stock GSR tranny and adding a JDM ITR final drive and LSD will cost quite a bit. Why not just buy a JDM ITR tranny that already has those and turn around and sell your GSR tranny to help offset the cost. You'd end up with even better gear ratios than you would with the modded GSR tranny, plus it won't cost as much in the end.
To answer your question about the gear ratios, the 98 spec JDM ITR tranny has 1st, 2nd, and 3rd gear equal to a B16 tranny, and 4th and 5th equal to a GSR tranny. All of them are shortened, however, due to the 4.785 final drive.
Old Mar 13, 2004 | 03:14 PM
ctrcivic's Avatar
Default Re: (Kendall)
Do you know of a reputable site were I can get a 98 spec ITR tranny
Old Mar 13, 2004 | 03:18 PM
Kendall's Avatar
Check out http://www.passwordjdm.com and http://www.hmotorsonline.com
If they don't have one, then they should be able to get you one.
Old Mar 13, 2004 | 03:33 PM
ctrcivic's Avatar
What is a GSR tranny worth in good working condition with no grinds. 97 model
Old Mar 13, 2004 | 03:35 PM
Kendall's Avatar
It all depends. I would think that if you found the right buyer, you could probably get seven or eight hundred bucks for it.
Old Mar 13, 2004 | 03:42 PM
Tweakmeister's Avatar
If you've got a Gs-R you're almost better off just buying a JDM ITR tranny, since it's got the right FD and LSD in there. Then it's as simple as ripping off the old tranny (selling it for some nice coin), and putting the JDM ITR on.
User Ketone went this route and his car is vastly improved.
Old Mar 13, 2004 | 04:06 PM
ctrcivic's Avatar
Thanks for the info. Has he had any trouble with the tranny grinding yet. Just wandering if I should have someone go through the tranny before I install it into my car. How many miles is on his tranny?
Thanks again
Old Mar 13, 2004 | 05:54 PM
Default Re: (ctrcivic)
I don't know....as long as you buy from a reputable importer then you should be fine (make sure they have some kind of gaurentee).
gsrob
Oct 10, 2007 12:48 AM
JDM_EK4_Coupe
12
Apr 28, 2007 04:50 PM
dc2_96gsr
Jan 30, 2007 05:34 PM
lowezz
Nov 28, 2004 09:17 AM
lowezz
Jul 8, 2001 12:54 AM
