swapping an ls tranny in my GSR
my syncro on second went so i cant get it in gear. i can pick up an ls tranny pretty cheap from a a kid who wrecked his car. i could use some help on how to do the swap. if you guys could help it'd be great. also does anyone know any good sites for info
Modified by GSRed at 10:56 PM 3/13/2004
unplug all sensors from tranny
take off clutch slave cyl.
remove flywheel cover and the 2 braces
remove all the bolts around the tranny that connect it to the block
remove the 2 19mm bolts on the driver side of the rear mount
remove the front tranny mount
get one person under the tranny, and one on top, and wiggle it out, (you might have to wedge it to get it started) and when it comes off, the bottom person has to bench press it and lay it on the ground.
then slide it out from underneth the car.
tallblondkid
Aug 11, 2004 01:32 AM
cr-x si
16
Jun 19, 2003 09:13 PM
