only cause i trust you guys more...
https://honda-tech.com/zeropost?cmd=fshow&id=15
having a slight problem with my motor, and i feel that this forum has the most correct/ educated diagnoses when it comes to problems.
get new injectors.....make sure wiring is correct...if it is a zc does that mean you did a dx to multipoint injection wire up?
if so your wires might be crossed...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sobe_Death »</TD></TR><TR><TD CLASS="quote">no i did the si to zc wiring, do the two white wires matter where they are? if so, what are the symptoms of them being wrong?</TD></TR></TABLE>
there is no si to zc conversion....you just move 2 wires from dizzy to the crank angle sensor...
douglaslovin
13
Mar 23, 2009 06:29 PM
