Idle problems again now with my h22
Old Mar 13, 2004 | 09:31 AM
matix's Avatar
Default Idle problems again now with my h22
I did search already. I already messed with idle screw. This did nothing. This idle is bad it goes from 700 to 3000. I just recenttly put my h22 throttle body on. It hasnt had no problems till now. I was using my f22 throttle body for cruise control. What should i check or could i have a blown head gasket.
Old Mar 13, 2004 | 09:55 AM
vc's Avatar
vc
Default Re: Idle problems again now with my h22 (matix)
sounds like a harsh problem. i would be scared if my idle went even to 2k rpm. lol
Old Mar 13, 2004 | 11:36 AM
95 acclude's Avatar
you might wanna check the IACV (idle air control valve) and if your throwing a check engine light you might wanna check the map sensor
Old Mar 13, 2004 | 07:50 PM
gotnos95's Avatar
I had the same prob with my 95 ex. the iacv (idle air control valve) on the back of the intake manifold was bad. replaced and all good for there.
********worth a try*********
Old Mar 13, 2004 | 11:46 PM
matix's Avatar
I took off the throttle body and then took off that gold plate. I dont know what it was called but it was loose inside their. I tightend that with a flat head it had some sort of spring loaded ball. This fixed the idle that was 700-3000. Everything was fine now i am getting a erratic idle of 700-1200. What should i check now.
Old Mar 15, 2004 | 09:28 AM
matix's Avatar
I just did the piece of metal over the two holes on the iavc and it idles perfect now. Thanks for responses.
m00nr0ck Si
Apr 1, 2009 04:17 PM
chinaski
Feb 15, 2006 05:04 PM
gutted-dx
Dec 18, 2005 09:08 PM
EMphaticONE
Jun 25, 2005 06:26 PM
Turbokid13
Feb 3, 2005 08:56 PM
