Problems with ZC motor????
Old Mar 13, 2004 | 08:56 AM
sicx's Avatar
Default Problems with ZC motor????
Im going to sound real dumb here but am stumped.
Now when I bought my last car from the auction ( 92 Civic HB), it has a ZC motor swap with p28 ecu, but the vtec is not working and the Check engine light is on.
I have no idea why it wouldnt work, the car drives good, but no vtec. Sorry im a noob at this stuff.
Any help is greatly appreciated.
Old Mar 13, 2004 | 08:57 AM
jameskersten1's Avatar
Default Re: Problems with ZC motor???? (TEGDOHCVTEC)
a ZC doesnt have vtec
Old Mar 13, 2004 | 09:08 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: Problems with ZC motor???? (jameskersten1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jameskersten1 &raquo;</TD></TR><TR><TD CLASS="quote">a ZC doesnt have vtec</TD></TR></TABLE>
are you sure about that???
my SOHC ZC has vtec. It's the JDM version of the D16Z6.
Clarify which ZC you have
Old Mar 13, 2004 | 09:10 AM
b16 matt's Avatar
Default Re: Problems with ZC motor???? (Emerika)
Are you talking about the old school non-vtec DOHC 1.6 litre engine or a z6 sohc.
Old Mar 13, 2004 | 09:12 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">
Clarify which ZC you have</TD></TR></TABLE>
i was thinking the DOHC ZC's, i have never seen a DOHC zc with vtec, and yeah the SOHC could have vtec (u know about them more then i do)
Old Mar 13, 2004 | 09:27 AM
sicx's Avatar
This is where i get lost...Is there numbers i can post to know if it really is Vtec? I know it says ZC on block and then there are numbers underneath it.
The valve cover says VTEC on it, but for all i know the Valve cover was just put on cause they didnt have another.
Old Mar 13, 2004 | 09:31 AM
93CivicSI's Avatar
Make sure the oil is up to the proper level, change it as well.
and also make sure coolant level is good, if there is air in the coolant vtec does not always engage.
Old Mar 13, 2004 | 09:37 AM
dinosa21's Avatar
Default Re: Problems with ZC motor???? (93CivicSI)
Is it DOHC OR SOHC?
Old Mar 13, 2004 | 09:41 AM
sicx's Avatar
Default Re: Problems with ZC motor???? (dinosa21)
SOHC
Old Mar 13, 2004 | 09:49 AM
then i would start with the basic stuff, check oil levels, coolant, vac lines. go from there.
Old Mar 13, 2004 | 09:52 AM
ProjektHB's Avatar
check if it has a vtec solinoid.
Old Mar 13, 2004 | 10:03 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: Problems with ZC motor???? (ProjektHB)
check your codes first....may be that vtec isn't wired up, ecu is bad, etc etc.
Could be a lot of things....you gotta help yourself out before we can try and help
Old Mar 13, 2004 | 10:09 AM
sicx's Avatar
Ok here are some pics of the engine...
Old Mar 13, 2004 | 10:21 AM
turbo_ef9's Avatar
looks like a vx motor.. it's got egr and what looks like a 5wire o2.. the im looks the same but the TB is 10x's bigger..
Old Mar 13, 2004 | 10:22 AM
5STAR3's Avatar
what auction did you get it from btw?
Old Mar 13, 2004 | 10:23 AM
Evs-One's Avatar
Solbros Owns Me
looks like the engine harness has the vtec plugs....but y0, you need to get rid of that exhaust manifold, like yesterday bro! lol
you can unplug the ecu, and see if the harness is pinned properly for vtec....I can't think of the locations off tha dome right now though....
Old Mar 13, 2004 | 10:24 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: Problems with ZC motor???? (eli_vang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eli_vang &raquo;</TD></TR><TR><TD CLASS="quote">looks like a vx motor.. it's got egr and what looks like a 5wire o2.. the im looks the same but the TB is 10x's bigger..</TD></TR></TABLE>
thinking the same thing..but if the block's stamped ZC....the car is probably a VX and he is just using the ZC longblock with the VX IM and EM
Old Mar 13, 2004 | 10:44 AM
turbo_ef9's Avatar
thinking the same thing..but if the block's stamped ZC....the car is probably a VX and he is just using the ZC longblock with the VX IM and EM </TD></TR></TABLE>
thas what i was thinkin.. haha.. i like that valve cover though..
Old Mar 13, 2004 | 12:49 PM
sicx's Avatar
Hey that valve cover is custom
I have no idea if they used VX head, but it is a CX model car.
I wish I could explain more but I did not have the engine installed.
Old Mar 13, 2004 | 03:43 PM
wisjdmhonda's Avatar
look like a vx motor to me. notice the cat under that heat shield also where the o2 sensor is... must be a vx
Old Mar 13, 2004 | 04:24 PM
turbotime's Avatar
smaller im, cat in header = vx id say
Old Mar 13, 2004 | 04:31 PM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEGDOHCVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Ok here are some pics of the engine...
This my friend is definately a d15 motor from a VX... I know because my wife has as VX and I just spent the last few hours under the hood replacing her dizzy...
VTEC?....yes....Fast?....no....Gas mileage?....oh yeah.(perfect for my wife)
Old Mar 13, 2004 | 05:04 PM
Cheivic's Avatar
Default Re: Problems with ZC motor???? (koreanwilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koreanwilcox &raquo;</TD></TR><TR><TD CLASS="quote">
It took you a couple hours to change a dizzy? haha just kidding with you.
Post a picture of the block stamp.
Old Mar 13, 2004 | 08:21 PM
sicx's Avatar
Default Re: Problems with ZC motor???? (Cheivic)
yea but I thought a Economy motor is not a ZC block? I could be wrong and probably am. I will have pic of stamp in morning.
Old Mar 14, 2004 | 07:33 AM
sicx's Avatar
now if the Head is from a VX motor, cant I just put a vtec head on? since it is a ZC long block
