Del Sol Dual Radiator In EG Coupe?
Is it true that the Del Sol DOHC VTEC Dual Core radiators are a direct bolt in to the 92-95 Civic??? I heard that they are, and that it is also a lot easier to install one of them in the civic over the Integra radiator... Please let me know... thank you...
Most aftermarket companies that make radiators just make the dual core one because it is better and will work in all applications as where the single core will not. By making just the dual core it is more universal and it will be a direct bolt in for almost all applications.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchVX »</TD></TR><TR><TD CLASS="quote">It should bolt right up to the EKs too. I would see why it wouldn't</TD></TR></TABLE>
yes it'll also go right into EK's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">
yes it'll also go right into EK's. </TD></TR></TABLE>
eg's/ej's/ek's its does fit
good upgrade
good upgrade
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by compwc18 »</TD></TR><TR><TD CLASS="quote">alright thanks, and one more question, is it the same size as the teg radiators?</TD></TR></TABLE>
No. It is the same size as the stock SOHC radiator, but in a two row or "dual core" configuration with larger diameter inlet and outlets.
No it is a dual core meaning it is 2 times as thick at the stock one not longer
I LUV MY EJ1
Aug 1, 2007 07:19 PM
sihatchyvtec
Jun 21, 2004 11:15 AM
