Brakes need pumping after startup or they dont work!
I just got finished installing a custom turbo kit and putting a semi-built motor in. For some reason after startup I need to pump the brakes to build pressure otherwise the pedal goes to the floor and the brakes do nothing.
I have the brake booster line connected to the intake manifold but what might be the cause of this? I didnt do anything involving the brakes and this is the 2nd turbo kit I've put on this car and the 4th time the motors been swapped and I've never had this problem before.
Thanks, I'm sure its something simple I overlooked!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salbaje »</TD></TR><TR><TD CLASS="quote">when you swapped motors you probably opened up the clutch slave cylinder. Bleed the brakes </TD></TR></TABLE>
The clutch slave is interconnected with the brake lines? I did have to refill the clutch slave because I had to swap rubber lines and the slave cylinder on the tranny, but I've done this a ton of times before with swaps and have never had a problem.
Thanks for the replys guys!
FWDrifter559
Sep 17, 2012 08:38 PM
92civicfreak
10
Jan 4, 2007 03:12 PM
project142
Oct 28, 2003 12:39 PM
