89 CRXSi, Fixed the starter, Now I got no juice on my plug wires/Dist.?????
Old Oct 18, 2001 | 03:18 PM
ZColeon's Avatar
New User
Default 89 CRXSi, Fixed the starter, Now I got no juice on my plug wires/Dist.?????
I fixed my starter issue earlier, Push start everywhere for a little while, Then the ****'n thing wont start, Worked the night before on a push, Now nothing, Replaced the Dist. Wires. Plugs. Swapped out ECU also, The weird thing is the L.E.D on it dosent light up at all, "Ground Problem"?????? I checked every where every fuse and ohm'd out my coil,.05......... Im so frustrated Im lost... Any suggestions would be cool..
Old Oct 18, 2001 | 06:01 PM
paulzy's Avatar
Default Re: 89 CRXSi, Fixed the starter, Now I got no juice on my plug wires/Dist.????? (ZColeon)
check your ground wires and test your igniter
Old Oct 19, 2001 | 08:40 AM
Speed PHreak's Avatar
There is usually a pestky ground wire on the back-sde of the tranny side of the motor near the starter. Make sure your starter has the power wire connected. Check your connections at the under-hood fuse box. When you turn the key, can you hear the fuel rail being pressurized?
[Modified by Speed PHreak, 5:41 PM 10/19/2001]
Old Oct 22, 2001 | 12:54 PM
ZColeon's Avatar
New User
Default Re: 89 CRXSi, Fixed the starter, Now I got no juice on my plug wires/Dist.????? (Speed PHreak)
I can hear my fuel rail build pressure, And still no fire, on my ignitor, which i cant seem to find, In my distributor, I replaced my coil, and stilll I do not see what they are talking about, this is a d15b7 with a 1.5 top , along with a 1.5 dist. seems like it is so simple but I still cant figure it out, Im in need of some seriouzsa help, And do you mean the ground wire that sits on the thermostat housing, I secured that , but have found no more wires?????????????????
Old Oct 22, 2001 | 12:59 PM
The ignitior is in the dizzy under the coil. it's alittle grayish box with 3 wires coming out of it. Pull out one of your plugs and try the start the car, see if you're getting spark to that plug. That'll help us narrow it down to an igntion problem if so.
Old Oct 22, 2001 | 03:18 PM
ZColeon's Avatar
New User
Changed the ignitor with a working known unit, and still no deal?
Old Oct 22, 2001 | 03:48 PM
ZColeon's Avatar
New User
Also did the spark deal, and we held all the plug wires and no spark, also removing the sparkplugs and leaving connected, still no spark. Seems like I have all the right voltages, and every thing ohms out to spec, but all in all it seems as if it were not recieving the signal to send the discharge to the plugs?
Any advice would help..
Old Oct 22, 2001 | 04:40 PM
paulzy's Avatar
check your fuses and relays, All of them...
it might be a problem with the ignition switch
Old Oct 23, 2001 | 07:03 PM
hybridmike's Avatar
Default Re: 89 CRXSi, Fixed the starter, Now I got no juice on my plug wires/Dist.????? (Slow_ass_4dr)
try the main wirind harness conector on the fender well.
Old Oct 23, 2001 | 08:53 PM
Lt. Dan's Avatar
Default Re: 89 CRXSi, Fixed the starter, Now I got no juice on my plug wires/Dist.????? (hybridmike)
check your main relay?
Dan
89CRX
Old Oct 24, 2001 | 09:07 AM
ZColeon's Avatar
New User
Default Re: 89 CRXSi, Fixed the starter, Now I got no juice on my plug wires/Dist.????? (Lt. Dan)
I checked the main relay and even tested it outside the car to see if it would turn on, it did but the problem is that when I plug it in and turn the key on it does not activate. Since the reay is not turning on the fual pump is not on either. I think this is somehow related to the computer not turning on either. Where does the main relay get its power to activate?
spoolin_eg
29
Jun 11, 2011 06:09 PM
immrtaltchnq
Sep 22, 2008 05:36 PM
Turbo Bora
May 15, 2007 08:27 AM
yoursupahero09
10
Jan 23, 2007 04:19 AM
bust
May 25, 2006 11:40 AM
