will GSR calipers fit an Eg coupe?
depends on what civic you have. if you have an EX or SI then they will fit, but anyother civic model you would need to get the gsr knuckle
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E 604 »</TD></TR><TR><TD CLASS="quote">yup EX/SI is a direct bolt on. for DX and lower, you need more.
dont forget to grab new brake pads too</TD></TR></TABLE>
GSR caliper are the same as the RS/LS/GS, 99-00 SI, 93-2000 Ex coupé
so don't lost your time to change it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">no, integra calipers are larger</TD></TR></TABLE>
What exactly is larger about them? The actual caliper, or the surface area of the piston?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">the caliper itself i believe</TD></TR></TABLE>
Don't the ABS equipped 92-95 EX coupe/sedan use the same brake pad part # (Looking thru different manufacturers application guides) as the 94+ Teg's?
That would lead me to believe they use the same "size" caliper, or am i just totally off in my thinking here?
their rotors are the same size (teg' and ex/si)</TD></TR></TABLE>
Integra Calipers have 2 Pistons, while Civic EX/SI Calipers have 1 Piston. Rotors are same size tho.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93 EJ1 »</TD></TR><TR><TD CLASS="quote">
Integra Calipers have 2 Pistons, </TD></TR></TABLE>
since when?
since when?
wow i've never heard of an iteg caliper having two pistons either...you'd think everyone would just up grade to that...but let me know if this is really true
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedquest510 »</TD></TR><TR><TD CLASS="quote">wow i've never heard of an iteg caliper having two pistons either...you'd think everyone would just up grade to that...but let me know if this is really true</TD></TR></TABLE>
Oops, my bad. Integ calipers only have one piston. I must've read that info wrong somewhere.
its not true. they are single piston, floating calipers, meaning they have a slide pin that allows puts the hydraulic force on both sides of the rotor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JV »</TD></TR><TR><TD CLASS="quote">
That would lead me to believe they use the same "size" caliper, or am i just totally off in my thinking here?</TD></TR></TABLE>
JV, I'll check the brake pad part numbers Monday when I get back to work. Also I'll check the various part numbers on the Civic coupe non-ABS and ABS and compare them to the 94-up Integra caliper part numbers as well. I've always *thought* the Integra calipers were larger than any 1994-1995 Civic Si/EX ones, but I'm not 100% on that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">JV, I'll check the brake pad part numbers Monday when I get back to work. Also I'll check the various part numbers on the Civic coupe non-ABS and ABS and compare them to the 94-up Integra caliper part numbers as well. I've always *thought* the Integra calipers were larger than any 1994-1995 Civic Si/EX ones, but I'm not 100% on that.</TD></TR></TABLE>
I am really curious to see the outcome of your findings. I too have heard they were larger, but have yet to witness in which way.
according to autozone.com, the parts are the same. don't know how much that amounts to.
BRAKE CALIPER - FRONT for a
1995 ACURA INTEGRA
FENCO_REMAN
DRIVER SIDE C8857 LLT $40.00 $43.99
FENCO_REMAN
PASSENGER SIDE C8856 LLT $40.00 $43.99
1995 HONDA CIVIC
ANTI-LOCK BRAKE SYSTEM (Change)
FENCO_REMAN
FENCO_REMAN
1995 ACURA INTEGRA
FENCO_REMAN
FENCO_REMAN
1995 HONDA CIVIC
FENCO_REMAN
FENCO_REMAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AmginE »</TD></TR><TR><TD CLASS="quote">according to autozone.com, the parts are the same. don't know how much that amounts to.
1995 ACURA INTEGRA
FENCO_REMAN
FENCO_REMAN
1995 HONDA CIVIC
FENCO_REMAN
FENCO_REMAN
Youi confirm what I said, all civic/integra with 10.3" rotor have the same calipers thank you very much
Everyone saying the aren't the same NEXT time shup up
1995 ACURA INTEGRA
FENCO_REMAN
FENCO_REMAN
1995 HONDA CIVIC
FENCO_REMAN
FENCO_REMAN
I just did my front DX to GSR brake conversion. The caliper is slightly larger vs. the civic one by a few mm (1-2) in height, length, depth. Rotors are slightly larger too, the diameter is larger by liek 1 or 2 mm. The brake pad on the GSR caliper covers a bit more surface though.
And yes you will have to replace the arm I believe. I suggest you put in the GSR master cylinder and brake booster too.
Modified by THEINTEGRATION at 3:13 PM 3/15/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akumaracer »</TD></TR><TR><TD CLASS="quote">depends on what civic you have. if you have an EX or SI then they will fit, but anyother civic model you would need to get the gsr knuckle</TD></TR></TABLE>
wtf again! This is like the 4th time in 2 minutes that people spout of complete and utter BS!
the 92-95 Si has the same EXACT front brakes as a CX/DX, etc....ONLY the Si's with ABS, offered in only 94 I believe had the Civic EX/Teg front brakes. I have a 94 without ABS and my stock fronts are same as a DX/VX/CX model
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garrett »</TD></TR><TR><TD CLASS="quote">
Before everyone ***** their pants thinking they know everything about these brakes, let me scan the real deal Honda and Acura part numbers DIRECTLY from the Parts Reference Guides...
Give me about 15 minutes to lay the smack down.
</TD></TR></TABLE>Before everyone ***** their pants thinking they know everything about these brakes, let me scan the real deal Honda and Acura part numbers DIRECTLY from the Parts Reference Guides...
Here we go guys, the scans.
First Integra:
Now Civic Hatchback - nevermind the incorrect info on the "1995 Si ABS" because trust me, they were only offered in 1994.
Now the Coupe - Nevermind the incorrect info on the "1992" Coupe. Coupes started in 1993. Also forget the "LX" portion as well. No such thing as an LX coupe until 2001.
Note the same colors equal the same part numbers. What does this tell us?
It tells us that only the ABS coupes share calipers with the Integras.
It also tells us that the Si hatch with ABS shares the same calipers as the Integras and ABS Civic coupes.
It shows us that the non-ABS 93-95 coupes did indeed have different calipers than the Integras and ABS Civics. This is according to part numbers from Honda. They in theory *might* could still be as large as the ABS and Integra ones, but I just doubt it.
It also shows us that all 1992-1995 hatches except the 1994 ABS have the same small calipers. This includes the 1994-1995 Si hatch which a lot of people swear has bigger brakes up front.
I will look at brake pad numbers to in order to see what the deal there is, but I honestly don't feel like scanning all of that **** right now.
First Integra:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage »</TD></TR><TR><TD CLASS="quote">ok now I am confused.. what all do I need to put on GSR calipers on my civic?</TD></TR></TABLE>
I cannot tell you the bare minumum required to get Integra-spec front calipers on your car, but I can tell you what I did on my own car.
I purchased complete front knuckle assemblies from a 1999 Integra GS-R. Really any 1994-2001 Integra, regardless of trim (except ITR - 5 lugs
) will work just fine.
I unbolted my upper balljoint, lower balljoint, and the puter tie rod end from the spindle and replaced the entire unit.
Doing it this way requires that you get an alignment since you're undoing the tie rod ends and also adding different spindles.
You can't go wrong this way.
) will work just fine.I unbolted my upper balljoint, lower balljoint, and the puter tie rod end from the spindle and replaced the entire unit.
