RODS FOR NA
N/A set-up.......stay stock your stock rods are good for well over 200+ HP (some would say 300HP), if not a set of eagle rods for like $340-$360 should be budgetable (is that a word).
Good luck!
Good luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by velocitytrends »</TD></TR><TR><TD CLASS="quote">N/A set-up.......stay stock your stock rods are good for well over 200+ HP (some would say 300HP), if not a set of eagle rods for like $340-$360 should be budgetable (is that a word).
Good luck!</TD></TR></TABLE>
eagle..
I would never run eagle rods any any motor.
N/A Rods.. my choices... Manley, Cunningham, IB Spec, Probe.. just to name some.
eagle..
i run probe ultra lights, there verry nice and verry light. not to bad for the budget either. they where like $350 or some thing like that.
i would recomend them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 FBP ItR »</TD></TR><TR><TD CLASS="quote">
You ever had an Eagle Break? $20 says no...you might know someone who knows someone who talks to someone on the internet that had one break...
IB Spec, Eagle, Probe...all that **** is made in china anyways...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave »</TD></TR><TR><TD CLASS="quote">
I agree...
Eagles are not as bad as some make them out to be
I agree...
The only problem with Eagle rods is that they weight a lot more than the stock rods. For NA motors, you want to lighten the assembly, not make it heavier...
Stock rods with ARP bolts are good for me!!!
I wonder why you even come up with that as your first assumption
, but no.
This is why....
They're heavy & not the best rods for na.
They're "budget", but i would much rather go w/ what Garth suggested if i was on the budget setup.
My first choice.. Cunninghams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garth »</TD></TR><TR><TD CLASS="quote">The only problem with Eagle rods is that they weight a lot more than the stock rods. For NA motors, you want to lighten the assembly, not make it heavier...
, but no.This is why....
Honda-Tech is such a goddam bandwagon....a year ago, noone barely knew about Cunningham....now suddenly everyone recommends them? With a 2-3 Month wait on a set...I wonder who has actually used them? They are good rods, but I don't understand how people 'recommend' stuff they haven't used.
i'm running shotpeend ls rods.. why not stick with stock rods?? theres some stock block b18c1s making 300whp with some monstor torque.. stock rods is the ultimate budget rod! if you really want to stregthen them get arp rod bolts, shot peening isnt really neccessary unless its some high milage rods
lets just say this...... honda wouldnt be here today if it werent for the good *** rod designs in the vtec motors.... i've seen people crack 300 (turbo of course ) on pump gas with stock rods and run on pump gas for a few years now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave »</TD></TR><TR><TD CLASS="quote">Honda-Tech is such a goddam bandwagon....a year ago, noone barely knew about Cunningham....now suddenly everyone recommends them? With a 2-3 Month wait on a set...I wonder who has actually used them? They are good rods, but I don't understand how people 'recommend' stuff they haven't used.
Assumptions, Assumptions, Assumptions.
I reccomend what I know works well, but it also depends on their budget.
I know it works b/c why? hmmm.
And its not that long of a wait, nor high of a price.. not much more than manleys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 FBP ItR »</TD></TR><TR><TD CLASS="quote">I know it works b/c why? hmmm.</TD></TR></TABLE>
Because you've seen someone with big post number write so ?
I'm joking of course but hype is a big negative of H-T.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommy69 »</TD></TR><TR><TD CLASS="quote">
I'm joking of course but hype is a big negative of H-T.</TD></TR></TABLE>
Indeed hype is a big thing... HT is also full of dyno bots.
But no hype here, just **** that performs.
Cunningham is gangsta...I was just commenting on th fact that alot of people comment on things thats are good\bad without personal experience. I wasn't really baggin' on you per se...just using your post as an example.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave »</TD></TR><TR><TD CLASS="quote">Cunningham is gangsta...I was just commenting on th fact that alot of people comment on things thats are good\bad without personal experience. I wasn't really baggin' on you per se...just using your post as an example.</TD></TR></TABLE>
Ok cool, I thought it was torward me..
All good now.
All good now.
