Tranny mount bolt nut came off !!Help!!!
Old Mar 12, 2004 | 04:13 PM
ki11a8ee's Avatar
Default Tranny mount bolt nut came off !!Help!!!
When i was pulling out the tranny mount bolt on the frame the nut broke off the inside of the frame. Now when i put the bolt back in the hole there is nothing there to screw the bolt on. Is there any way to fix this problem?
Old Mar 12, 2004 | 04:34 PM
Dan GSR's Avatar
Default Re: Tranny mount bolt nut came off !!Help!!! (ki11a8ee)
which mount?
ther upper transmission mount?
or the lower transmission mount?
either way, best thing to do is get a washer, and a new nut, and put it on the back of the frame
Old Mar 12, 2004 | 04:55 PM
doublejz's Avatar
Default Re: Tranny mount bolt nut came off !!Help!!! (Dan GSR)
hrm first I thought the tranny mount bracket was welded to the frame. and the bracket had 3 bolts to the tranny but anyway. When reading your question i get two different ideas what happened.
1. a piece of the frame itself broke off = weld a piece on
2. the nut broke off that was welded to the frame = get a long *** bolt and drill out the other side of the frame and put the bolt the whole way through and nut it.
Old Mar 12, 2004 | 05:51 PM
ki11a8ee's Avatar
Default Re: Tranny mount bolt nut came off !!Help!!! (doublejz)
thanks doublejz number 2 is what happened and ill try using a long bolt and nut.
thanks for ur help
george34
13
Feb 22, 2006 11:09 AM
ki11a8ee
13
Mar 14, 2004 03:09 PM
Trbospnkr
Feb 8, 2004 02:05 PM
cvcc
Jan 5, 2003 09:35 PM
