Borg Warner 7mm plug wires?
anyone have experience w/ these plug wires??? dont say get NGK because i already have them and if enough people tell me they suck *** w/ personal experience, ill take them back and get ngk. thanx
Someone once posted a site with some chart that showed stock wires are the best you can buy. I don't even have the slightest clue who posted it, or what the site was. You may want to take that into consideration.
Yet another situation where OEM proves to be about the best that you can get. Aftermarket plug wires are bling and sell on claims of increased power, but I don't see too many dyno charts that say otherwise.
right, its a local parts store and i did ask for the ngk's but these were the best they had. so no one has had crappy experiences w/ them??? i already have them and if i have too ill take them back.
i've used the borg warner plug wires before. and to tell you the truth, they work just like stock.
except when you want to change your spark plugs again. One of the spark plug rubber caps got stuck and wouldn't come out. Had to use long needle nose pliers to remove.
I wouldn't recommend buying even if they do have lifetime warranty. too much hassle and stock isn't much more expensive.
