will EG ebrake cable work?
i bought a set of 94 si rear disc..and this is gonna go on my 90 STD hb..would the EG ebrake cable work? or do i need the DA?
Brackets may be a little off, but should work out fine without too much if any extra length. Never actually done it, but based on the length of both vehicles, should be fine.
Most are probably too cheap to run newer brakes than 93- teg
I've done a number of rear disc conversions on all different years, and from what I have seen they look very similiar in length, but never taken the time to measure it all out. You may want to ask Black R, if he used the integra brake cables on his conversion, that will solve it for ya cause teg=EG
thats what i was thinking.. eg = teg. but just dont know if theres a difference in DA and DC. anyways..so i purchases the rear disc off the 94 si.. came with trailing arm, hub, rotors, calipers..and he said this system has abs and hydrolics system. now i know i can leave off the hydrolics. it didnt come with brake lines..would my stock lines hook right up? and he also told me 1 of the upper control arm is slightly bent..can i use my stock on as well?
Use your stock everything as far as suspension is concerned. Unbolt the four torx bolts and the large 32mm nut and remove the hub assembly from the trailing arm, and do the same on your car, then install the disc hub on your stock trailing arm. As for the brake lines, your lines will not work, you will need brake lines from a disc brake equipped car like a 92-5 Si or 90-3 teg or 90-1 CRX Si. I would recommend the purchase of a set of goodridge stainless brake lines, which can be had for $130 or less. Do some searching, there is tons of good info to be had
killerpenguin21
Apr 30, 2010 08:27 PM
FastAsleep
Jan 12, 2007 03:47 PM
