*Quickie: Spark plug gap, trying the BKR7E's....
Old Mar 12, 2004 | 02:42 PM
Beave0101's Avatar
Default *Quickie: Spark plug gap, trying the BKR7E's....
just giving them a shot, what should i gap these at? It's been so long, and i couldnt yield the info i was looking for in anything that came up in a search.
.030/.034/.035/.040 ?
B16 motor, 11.1 cr
thanks
Old Mar 12, 2004 | 02:50 PM
BERT-O's Avatar
Default Re: *Quickie: Spark plug gap, trying the BKR7E's.... (Beave0101)
.040
But, you can tried some other gaps and see how it works, just a though btw
Old Mar 12, 2004 | 03:16 PM
Beave0101's Avatar
Default Re: *Quickie: Spark plug gap, trying the BKR7E's.... (BERT-O)
thanks, for some reason i had it in my mind to gap these closer to .035...
Old Mar 12, 2004 | 04:25 PM
L-B racing's Avatar
7E's should have a .30 gap. 7E11's should be a .36 gap. we've found that our stuff likes to be in between these 2.
Old Mar 12, 2004 | 10:52 PM
Beave0101's Avatar
Default Re: *Quickie: Spark plug gap, trying the BKR7E's.... (L-B racing)
well is the CR of the engine relative to gap of the plugs?
Only 11.1 cr in a B16..........I never really looked into spark plugs so much so i dont really know the theory behind it all
Old Mar 13, 2004 | 05:26 AM
L-B racing's Avatar
theres alot of things that can affect what plugs to use. id start with some 7e stuff and then get some 6E's and try them. it might help in a lower comp motor to have the hotter spark. the gap depends on if you have a msd or stock ignition. its easy to play around with since plugs are so cheap. im just lucky that NGK sponsored us so i got to learn alot about them.
Old Mar 13, 2004 | 06:43 AM
BERT-O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by L-B racing &raquo;</TD></TR><TR><TD CLASS="quote">7E's should have a .30 gap. 7E11's should be a .36 gap. we've found that our stuff likes to be in between these 2.</TD></TR></TABLE>
He is correct, again, like I mention before, you can tried some other size gap and see how it works. But I don't like to say what I set mine since every engine is different, as far as setup goes, or may hurt it as far as performance.
If you can, tried Rockets' plugs.
-Bert
JDM_lover03
Aug 15, 2005 10:14 AM
pa2play
Jul 25, 2004 01:15 PM
b16beast
Jan 5, 2003 11:09 AM
aznchino16
Apr 8, 2002 01:25 PM
keys
Aug 8, 2001 07:52 AM
