high compression = lower vacuum pressure ??
Old Mar 12, 2004 | 01:53 PM
VTgringo's Avatar
Default high compression = lower vacuum pressure ??
anyone with high compression seen a variation in vacuum pressure at idle? I am running a 12.4:1 cr. I can't find any vacuum leaks yet my gauge says 15inHg at 750rpm idle. this is a bit different from what my engine use to run (22inHg) with the 9.5:1 cr.
thanks for any input
Old Mar 12, 2004 | 02:05 PM
JaeOne3345's Avatar
Default Re: high compression = lower vacuum pressure ?? (VTgringo)
Did you change camshafts along with the compression upgrade?
Old Mar 12, 2004 | 02:35 PM
VTgringo's Avatar
Default Re: high compression = lower vacuum pressure ?? (JaeOne3345)
no, stock cams......any idea?
Old Mar 12, 2004 | 03:47 PM
VTgringo's Avatar
bump
Old Mar 12, 2004 | 07:55 PM
evilxkid's Avatar
it dose sound like a cam isue. so your cam timing line up right. maby a cam gear slipped.
Old Mar 14, 2004 | 04:47 PM
VTgringo's Avatar
Default Re: high compression = lower vacuum pressure ?? (evilxkid)
really, cams can cause this problem. anyone else heard of this?
Old Mar 15, 2004 | 06:26 AM
Darkteg's Avatar
New User
would like to know more about this too, after installing an ITB setup vacuum changed from 15psi at idle to 8psi... what to do/how to compensate a/f readings with lower vacuum pressure?
Old Mar 15, 2004 | 01:16 PM
VTgringo's Avatar
Default Re: high compression = lower vacuum pressure ?? (Darkteg)
bump, any ideas?
Old Mar 17, 2004 | 08:04 PM
JdM_Eg_6's Avatar
bump for good question
Old Mar 17, 2004 | 11:42 PM
Eddiebx's Avatar
did u have any head work done? particularly a valve job?
Old Mar 18, 2004 | 01:17 AM
leadfoot78's Avatar
Big cams will deffinitely lower your vacum pressure, messed up timing will too. Losing vacum pressure cuz of cams is mostly a problem for the V8's since none of them have v-tec, one cam lobe for every rpm makes for alot of lift and overlap at idle and the motor can't make vacum. I think u have a problem, like a leak or bad timing, your idle speed should also be wierd too.
Old Mar 18, 2004 | 07:29 AM
EE_Chris's Avatar
Default Re: high compression = lower vacuum pressure ?? (leadfoot78)
Does higher compression increase reversion back into the intake? If it does, perhaps that is what is causing it.
Verified cam/crank timing?
Kozy.
Jul 6, 2012 03:09 PM
meanEG
12
Jul 1, 2004 07:42 AM
85mm LsVTEC
34
Jan 25, 2004 04:56 PM
IntegD
Jan 25, 2002 05:45 PM
HX_Guy
Dec 7, 2001 04:28 PM
