Harness Bar?
Old Mar 12, 2004 | 11:52 AM
Demon_Dub's Avatar
Default Harness Bar?
Is there a harness bar that bolts into the stock seatbelt points? Please post a name or link, Thanks!
Old Mar 12, 2004 | 12:14 PM
SuzukaBlueAP2's Avatar
Default Re: Harness Bar? (Demon_Dub)
No.
There is a bar that goes across there, it is called a C Pillar bar.
It is not meant for mounting harnesses to.
Check out http://www.ioportracing.com for roll bars and harness bars.
Old Mar 12, 2004 | 12:26 PM
typeR#0427's Avatar
Default Re: Harness Bar? (ScreaminTeg)
There is one. I think that it was in the last issue of Honda-Tuning. Lokar Racing or something.
*damn I can't find that issue*
I know its in there. Towards the back. I will search around.
Modified by hamB18C1 at 2:40 PM 3/12/2004
Old Mar 12, 2004 | 12:29 PM
One Bad GeeSeeR's Avatar
Default Re: Harness Bar? (hamB18C1)
http://www.lokarmotorsports.com/harnessbar.html
Carlo
Old Mar 12, 2004 | 12:41 PM
typeR#0427's Avatar
Default Re: Harness Bar? (One Bad GeeSeeR)
[fat bastard] ooh, Thats it! [fat bastard]
Thanks
Old Mar 12, 2004 | 12:55 PM
Demon_Dub's Avatar
yup thats the one, is LokaR known for making good products? Seatbelt mounting is one of the things I consider slightly important if ya know what I mean.
Old Mar 12, 2004 | 01:30 PM
rapid_roy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demon_Dub &raquo;</TD></TR><TR><TD CLASS="quote">yup thats the one, is LokaR known for making good products? Seatbelt mounting is one of the things I consider slightly important if ya know what I mean. </TD></TR></TABLE>
May I ask what you are intending to do with your car?
If you are taking it on track, it's a horrible idea. Horrible as in fatal if you roll.
For autox: The chance of rolling is very small, so it's less of a bad idea. With a 4pt harness it will keep you planted in your seat.
Street: Think of the passengers!
Old Mar 12, 2004 | 01:34 PM
MooreBoost's Avatar
Default Re: Harness Bar? (rapid_roy)
Bad idea in all cases if you ask me. Dont halfass safety.
Old Mar 12, 2004 | 01:45 PM
Demon_Dub's Avatar
Default Re: Harness Bar? (tegunderpressure)
Just tossing around idea's. Why is it such a bad idea? I was looking at it as a median between a cage and nothing. But like I said safety is more important then anything.
Old Mar 12, 2004 | 07:13 PM
MooreBoost's Avatar
Its the decapitation theory. Harnesses are designed to work in conjunction with fixed back racing seats, and a roll cage. Take one out, and it all fails. The harnesses will keep you upright in a wreck, keeping you from moving to the inside of the car, if the roof collapses when you roll you will not be able to move, and you will be decapitated.
Old Mar 12, 2004 | 07:29 PM
emissionsux's Avatar
That's true, I actually designed a harness bar that moved the pillar farther back. Decided not to market it because of safety reasons. It was a nice design too. I just have one prototype that was built, then scrapped the idea.
Old Mar 12, 2004 | 07:36 PM
B18C_eg's Avatar
Default Re: Harness Bar? (emissionsux)
speedwaremotorsports.com
Old Mar 12, 2004 | 08:06 PM
Kendall's Avatar
At the very least, get a good roll bar. Autopower makes one that can usually be had for between $300 and $400.
Old Mar 15, 2004 | 08:43 PM
Default Re: (Kendall)
If you get a rollbar, make sure to get the SFI paddding for it. Also, you rally shouldn't drive on the street with the harnesses on, safety reasons.
Old Mar 15, 2004 | 08:46 PM
LSTEG96's Avatar
Default Re: (emissionsux)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emissionsux &raquo;</TD></TR><TR><TD CLASS="quote">If you get a rollbar, make sure to get the SFI paddding for it. Also, you rally shouldn't drive on the street with the harnesses on, safety reasons.</TD></TR></TABLE>
why? padding on the bar? if ur in your seat, theres no way ur gonna touch that bar, unless u really **** somethin up!
Old Mar 15, 2004 | 08:47 PM
thaiphob's Avatar
Nikon!!!
if you value your life get a full cage.
Old Mar 15, 2004 | 08:59 PM
Kendall's Avatar
Default Re: Harness Bar? (thaiphob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thaiphob &raquo;</TD></TR><TR><TD CLASS="quote">if you value your life get a full cage.</TD></TR></TABLE>
I wholeheartedly agree.
Old Mar 16, 2004 | 06:52 AM
MooreBoost's Avatar
People have cracked their helmets on padded rollbars in the past.
victormak91
Aug 19, 2009 10:33 PM
Greg H
Nov 26, 2007 04:39 PM
xJadieMx
Welding / Fabrication
Jul 9, 2005 12:38 PM
H22A EG6
17
Mar 1, 2004 12:30 PM
Xx D-MAN xX
Dec 27, 2003 12:47 PM
