Tire size question????
Old Mar 12, 2004 | 08:10 AM
SleepinTeg's Avatar
Default Tire size question????
I have a 98 Teg with Eibach Prokit. I am looking for 17 drag tires. I am wondered can i have 225 40 17 on my front wheel? Also, what drag tires last longer and has decent grip? Thx
Old Mar 12, 2004 | 08:35 AM
Creep's Avatar
Default Re: Tire size question???? (SleepTeg)
225/40/17 will not fit without some modification
Old Mar 12, 2004 | 09:56 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: Tire size question???? (Creep)
how wide are your rims?
Old Mar 12, 2004 | 08:09 PM
SleepinTeg's Avatar
Default Re: Tire size question???? (dLo GSR)
My rim size is 17x7
Old Mar 12, 2004 | 08:14 PM
Kendall's Avatar
There aren't a lot of drag tires out there to fit 17's. There are even fewer that will fit "skinny" 17's (17x7 is considered skinny). If you had some 17x9's, then you wouldn't have much of a problem, but we all know what would happen if you tried to put 17x9's on an Integra.
Old Mar 12, 2004 | 10:56 PM
xteg95's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Creep &raquo;</TD></TR><TR><TD CLASS="quote">225/40/17 will not fit without some modification</TD></TR></TABLE>
Old Mar 14, 2004 | 08:24 PM
96dc2's Avatar
Why not drag with 14's or 15's?
Old Mar 14, 2004 | 08:29 PM
cougar10ag's Avatar
i got 215/40/17 with a 1.75 drop in the front and they only rub at full lock and if i'm moving quickly or hit a bump.
thesidewall height difference between a 215/40/17 and a 225/40/17 is 4mm.
if these are track only then they will do fine as you won't be tunring undr speed so you won't need to worry about rub. if they are street i would go with 225/40/16.
besides unless you got gobs of power you shouldn't be dragging with 17's. just pick up some steelies.
aln2590
Aug 6, 2007 09:16 AM
Charliegrs
Oct 8, 2006 12:26 AM
Quad-Damage
Apr 17, 2006 03:27 PM
"Hites"
Jan 5, 2005 08:06 PM
CaptivaBlue
Oct 3, 2004 01:24 PM
