Whitch spark plugs/wires and gap to use with a b16b motor? Same specs as usdm b16a?
Old Mar 12, 2004 | 07:34 AM
mrtrex's Avatar
Default Whitch spark plugs/wires and gap to use with a b16b motor? Same specs as usdm b16a?
I need to pick some up. Just making sure I am getting the right stuff. The motor is stock by the way.
Old Mar 12, 2004 | 10:53 AM
RedlinedVTEC's Avatar
Default Re: Whitch spark plugs/wires and gap to use with a b16b motor? Same specs as usdm b16a? (mrtrex)
NGK BKR6E-11 should be just fine for you, use stock gap specs.
Old Mar 12, 2004 | 11:58 AM
mrtrex's Avatar
Default Re: Whitch spark plugs/wires and gap to use with a b16b motor? Same specs as usdm b16a? (RedlinedVTE
Do you mean stock gap specs for a usdm b16 or the jdm b16b?
Old Mar 12, 2004 | 02:22 PM
doublejz's Avatar
just throw some NGK BKR6E-11 in, they are somewhat cold plugs and also heard they work well with nos
Old Mar 12, 2004 | 05:45 PM
I run them in my B16 with CTR pistons and a milled head at .048 spec. Stock spec runs between .047-.051.
jvr
Apr 26, 2014 02:24 AM
namewasdallas
20
Dec 12, 2009 10:38 AM
Powered by VTEC
29
Jan 25, 2008 10:47 PM
92 white eg
11
Dec 13, 2006 09:53 AM
Jdmb16sir2
May 2, 2006 09:59 PM
