wich sleeves has the best price?
Old Mar 12, 2004 | 04:59 AM
Carlo Gambino's Avatar
Default wich sleeves has the best price?
i see exospeed slevees for $290 ,is there another low price with the same or more quality?? not tryin to disscussing this bad and this good ,just need an personal oppinion .
Thanks
Old Mar 16, 2004 | 04:41 AM
boink..
Old Mar 18, 2004 | 09:51 AM
ExospeedAMcrx's Avatar
Default Re: (Carlo Gambino)
keep in mind our sleeves come as Universal Blanks. they can be bore, machined to whatever spec your machine shop likes to do it. like the B sleeves, they come with an 80mm Inside diam. and can be bored to 87mm.
your machine shop can also cut the flat sides how they want.
Old Mar 18, 2004 | 09:56 AM
AllMotorMadness's Avatar
Default Re: wich sleeves has the best price? (Carlo Gambino)
Exospeed Sleeves
Old Mar 18, 2004 | 03:30 PM
riceball777's Avatar
$290
dont sleeves normally cost close to a grand ????
Old Mar 18, 2004 | 04:13 PM
jt-sport's Avatar
Will.. did you have one for D -serries ??
Old Mar 18, 2004 | 05:11 PM
Maddox's Avatar
As anyone used exospeed slevees ??
Old Mar 18, 2004 | 05:23 PM
dmotoguy's Avatar
Default Re: wich sleeves has the best price? (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">$290
dont sleeves normally cost close to a grand ????</TD></TR></TABLE>
installed.
Old Mar 22, 2004 | 02:46 AM
yea, how about the D serries sleeves. do you have one EXOSPEED ?? and how about the price??
Old Mar 22, 2004 | 07:35 AM
we only have B and H Universal sleeves right now.
no D series.
Sleeves are $290.00
Installed is $880 . includes bore, hone, hot tank and deck the block.
Old Mar 24, 2004 | 08:48 PM
ChillOutWayne's Avatar
Default Re: (exospeedAMcrx)
how much work is really involved with installing sleeves?
Old Mar 25, 2004 | 11:11 AM
Default Re: (ChillOutWayne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChillOutWayne &raquo;</TD></TR><TR><TD CLASS="quote">how much work is really involved with installing sleeves?</TD></TR></TABLE>
the stock cylinders are Cut and machined to fit the NEW Iron Ductile Sleeve. It is pressed in the block and block is decked after for flat surface.
Old Mar 25, 2004 | 11:14 AM
well my machinist typically deals with V8 motors, and he gives me a pretty good discount for work. is this something he would be able to do, or at least typically?
Old Mar 25, 2004 | 11:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChillOutWayne &raquo;</TD></TR><TR><TD CLASS="quote">well my machinist typically deals with V8 motors, and he gives me a pretty good discount for work. is this something he would be able to do, or at least typically? </TD></TR></TABLE>
well the main thing is he would have to figure out his own specs and way of Cutting the block. I suggest sending it to us or RS machine. We specialize in these blocks and no need to have to LEARN how to do it.
Old Mar 26, 2004 | 11:42 AM
Darton Sleeves's Avatar
what block do you have?
Old Mar 27, 2004 | 07:56 PM
Default Re: wich sleeves has the best price? (Darton Sleeves)
B18C1, and i already have CP 9:1 OS pistons in there, with Eagle H beams that id be reusing. just wondering cause if i ever go for more power, im gonna sleeve, and wat wondering the process and price, cause this mullett shop gives me a huge deal. For my bore, hone, and complete bottom end assembly with bearings (federal mogul) platigagued he only charged me 225, and im using his shop to install the turbo for no charge, so i figured id ask.
Old Mar 28, 2004 | 04:39 PM
jt-sport's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darton Sleeves &raquo;</TD></TR><TR><TD CLASS="quote">what block do you have?</TD></TR></TABLE>
my D16 lookin for cheap sleeves
Old Mar 29, 2004 | 12:55 AM
RS Machines's Avatar
I wouldnt recommend sending any blocks to a machine shop that has no knowledge of sleeving honda blocks....It will cost you more in the long run......Be ready to sacrafice your block
Old Mar 29, 2004 | 05:39 AM
Default Re: (RS Machines)
ok so do companies that sleeve blocks typically bore and hone the block also? also wats a general price range for that, 800 or so?
Old Mar 29, 2004 | 07:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChillOutWayne &raquo;</TD></TR><TR><TD CLASS="quote">ok so do companies that sleeve blocks typically bore and hone the block also? also wats a general price range for that, 800 or so? </TD></TR></TABLE>
our complete Sleeving service with Bore and Hone is $880.00
Its best to just send to us since we already know the process for the Honda stuff.
Old Mar 30, 2004 | 03:04 PM
Default Re: wich sleeves has the best price? (jt-sport)
We do offer sleeves for the D-Series blocks. Regular flanged sleeves and MID closed deck...
Old Mar 31, 2004 | 01:56 AM
jt-sport's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darton Sleeves &raquo;</TD></TR><TR><TD CLASS="quote">We do offer sleeves for the D-Series blocks. Regular flanged sleeves and MID closed deck...</TD></TR></TABLE>
how much it will be ?? im asking a bare sleeves, because im not gonna machine my block anywhere in America ,
since im living far far far far far away from america .....
Old Mar 31, 2004 | 08:27 AM
send me a email with all your info...customerservice@darton-international.com
Topdawgg
Nov 12, 2006 06:41 PM
WVTURBOCRX
Dec 29, 2005 03:28 PM
Boostage
Jun 19, 2005 07:30 PM
Desperado
Sep 26, 2003 09:59 PM
harkaysports
Jun 17, 2003 12:44 AM
